LCD Screen and LED no longer blinking when changing power sources
I am using a 20x4 LCD screen to display certain recorded values. I get it to work when it is connected to my computer, however, once I change it to be plugged into a battery or wall outlet the display just displays white boxes on the 1st and 3rd rows. I have clearly updated a code to it but it still doesn't work. The led that I have connected also doesn't blink when it is plugged into battery or wall outlet either. I was wondering why the difference in output when power source changes and any potential fixes. Thank you in advance.
LCD Screen: https://www.amazon.com/gp/product/B0080DYTZQ/ref=s9u_simh_gw_i1?ie=UTF8&fpl=fresh&pd_rd_i=B0080DYTZQ&pd_rd_r=fae5e15f-fe1f-11e7-bd6b-0356965b604e&pd_rd_w=hHfld&pd_rd_wg=jsWEF&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=0JQ9RET26YK58SP17G92&pf_rd_t=36701&pf_rd_p=d9f78c36-24d5-402e-866f-a50358a0504c&pf_rd_i=desktop
LED: https://www.amazon.com/gp/product/B00KWGJWYM/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
#include <Wire.h>
#include <LCD.h>
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7);
const int ledPin = 13;
int ledState = LOW;
unsigned long previousMillis = 0;
  pinMode(ledPin, OUTPUT);
  lcd.setBacklightPin(3,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.begin(16, 2);
  lcd.setCursor(0,0);
  lcd.print("RPM = ");
  lcd.setCursor(0,1);
  lcd.print("Temp (F) = ");
  lcd.setCursor(20,0);
  lcd.print("Bearing Life = ");
  unsigned int interval = analogRead(A2);
  if (currentMillis - previousMillis >= interval) {
    lcd.setCursor(6,0);
    lcd.print(interval);
    digitalWrite(ledPin, !digitalRead(ledPin));
You have not shown how the LEDs and LCD are connected to your Arduino and to your power source.
Did you think that does not matter?
ieee488:
The power source is from the power jack using a wall adapter, and the other is from the USB connector. To answer your question yes I do think it matters, however it works completely fine when it is connected via USB to my computer, but not on the power jack. I can post pictures however I do not see why that would change the output.
predzZzZzZ:
Yeah photos.
Here are some images I have included.
These two images exceeded file size on the last post.
It seems that the pot is plugged into the wrong holes of the breadboard.
Leo..
