I am making a robotic arm to hold my PCB's & flip them & raise them & what not (just for fun there is no reason other then that), but I can't find any info on having the servos hooked up to the arduino along w/ an LCD screen & selector setup (IE joystick & pushbutton) so that I can choose the servo controll options.
Please help me out w/ this, I will answer questions as I best I can.
There is plenty about servo control and there are menu libraries.
Have you looked in the Playground?
I have looked @ the playground & all I see is things about servo control w/ & w/out a knob & servo, & things about LCD screens but not about using them to controll objects, just getting them to display text.
What I am needing if I can get it, I'll use another route if I have to by using individual switches & potentiomiters but what I'd like to do is have an LCD screen w/ the options to change the positions of the servos. But as I stated I can't find anything that has that kind of info.
AWOL:
LCDs are display devices; they can't control anything.
Are you talking about touchscreens?
So your telling me that I can't have an LCD screen display what I want to do & then when it is selected the arduino triggers those actions. & no I'm not talking about a touchscreen, that's too expensive.
I'm guessing the OP meant that his screen will display a menu and the buttons on the screen will dictate what happens next.
@the OP, the buttons on the lcd board (assuming your board has buttons, of course) are all connected to an analog pin and thru a cunning network of resistors each outputs a different voltage. You then use that voltage as read on the analog input to decide which button is pressed, and then use that fact in (for instance) a switch case with each case containing the code for what you want to happen.
