My Screen goes out after the program is loaded.
I am sure it is a syntax problem or something but I cant find it.
Would someone try this on your uno board and see if it gives the same result?
Does anyone see what I have done wrong? I am using a shield LCD that works fine until I get to this point.
The Program
#include <LiquidCrystal.h>
LiquidCrystal
lcd(8, 9, 4, 5,6, 7);
int h = 17; //Here h= is the hours for the time of day it could be 1-24//
int m =0; //here m= is the minutes for the time of day it could be 1-59//
int s=0; // here s= is the seconds for the time of day usually left at 0//
int hao = 17; //Here h = is the hours for the Light on it could be 1-24//
int mao = 0; //here m = is the minutes for the Light on it could be 1-59//
int haf = 17; //Here h = is the hours for the Light off it could be 1-24//
int maf = 1; //here m = is the minutes for the Light off it could be 1-59//
int hwateron= 17; //Here h= is the hours for the water Pump on it could be 1-24//
int mwateron=01;//here m= is the minutes for the water Pump on it could be 1-59//
int hwateroff= 17; //Here h= is the hours for the water Pump off it could be 1-24//
int mwateroff=02; //here m= is the minutes for the water Pump off it could be 1-59//
int hpumpon = 17; //Here h= is the hours for the water Pump on it could be 1-24//
int mpumpon =03; //here m= is the minutes for the water Pump on it could be 1-59//
int hpumpoff = 17; //Here h= is the hours for the water Pump off it could be 1-24//
int mpumpoff=04; //here m= is the minutes for the water Pump off it could be 1-59//
int hpumponn = 17; //Here h= is the hours for the water Pump on it could be 1-24//
int mpumponn =5; //here m= is the minutes for the water Pump on it could be 1-59//
int hpumpofff = 17; //Here h= is the hours for the water Pump off it could be 1-24//
int mpumpofff=6; //here m= is the minutes for the water Pump off it could be 1-59//
int hpumponnn= 17; //Here h= is the hours for the water Pump on it could be 1-24//
int mpumponnn=7; //here m= is the minutes for the water Pump on it could be 1-59//
int hpumpoffff= 17; //Here h= is the hours for the water Pump off it could be 1-24//
int mpumpoffff=8; //here m= is the minutes for the water Pump off it could be 1-59//
int hgasinjecton = 17; //Here h= is the hours for the CO2 Pump/Valve on it could be 1-24//
int mgasinjecton =9; //here m= is the minutes for the CO2 Pump/Valve on it could be 1-59//
int hgasinjectoff = 17; //Here h= is the hours for the CO2 Pump/Valve off it could be 1-24//
int mgasinjectoff =10; //here m= is the minutes for the CO2 Pump/Valve off it could be 1-59//
int hExtraon = 17; //Here h= is the hours for the CO2 Pump/Valve on it could be 1-24//
int mExtraon =11; //here m= is the minutes for the CO2 Pump/Valve on it could be 1-59//
int hExtraoff = 17; //Here h= is the hours for the CO2 Pump/Valve off it could be 1-24//
int mExtraoff =12; //here m= is the minutes for the CO2 Pump/Valve off it could be 1-59//
int fert = 17;
pinMode(1,OUTPUT);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(10 ,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
pinMode( A0 ,OUTPUT);
pinMode( A1 ,OUTPUT);
pinMode( A2 ,OUTPUT);
pinMode( A3 ,OUTPUT);
pinMode( A4 ,OUTPUT);
pinMode( A5 ,OUTPUT);
if ((h == hwateron)and(m == mwateron)) digitalWrite(1, HIGH),digitalWrite(2,HIGH);
if ((h == hwateroff)and(m == mwateroff)) digitalWrite(1,LOW),digitalWrite(2,LOW);
if ((h == hpumpon)and(m == mpumpon)) digitalWrite(3, HIGH),digitalWrite(11,HIGH);
if ((h == hpumpoff)and(m == mpumpoff)) digitalWrite(3,LOW),digitalWrite(11,LOW);
if ((h == hpumponn)and(m == mpumponn)) digitalWrite( A0 , HIGH),digitalWrite( A1 ,HIGH);
if ((h == hpumpofff)and(m == mpumpofff)) digitalWrite( A0 ,LOW),digitalWrite( A1 ,LOW);
if ((h == hpumponnn)and(m == mpumponnn)) digitalWrite( A2 , HIGH),digitalWrite( A3 ,HIGH);
if ((h == hpumpoffff)and(m == mpumpoffff)) digitalWrite( A2 ,LOW),digitalWrite( A3 ,LOW);
if ((h == hgasinjecton)and(m == mgasinjecton)) digitalWrite( A4 , HIGH),digitalWrite(10,HIGH);
if ((h == hgasinjectoff)and(m == mgasinjectoff)) digitalWrite( A4 ,LOW),digitalWrite(10,LOW);
if ((h == hExtraon)and(m == mExtraon)) digitalWrite(11, HIGH),digitalWrite(12,HIGH);
if ((h == hExtraoff)and(m == mExtraoff)) digitalWrite(11,LOW),digitalWrite(12,LOW);
if ((h == hao)and(m == mao)) (digitalWrite( A5 , HIGH)), (digitalWrite( 13 ,HIGH));
if ((h == haf)and(m == maf)) (digitalWrite( A5 ,LOW)),(digitalWrite( 13 ,LOW));
lcd.begin(16, 2);
lcd.setCursor(0,1);
lcd.clear();
lcd.print(“TIME:”);
lcd.print(h);
lcd.print(":");
lcd.print(m);
lcd.print(":");
lcd.print(s);
