LCD SD Slot Card
Dear all,
I have done tests with Display Module LCD Screen 320x240 ILI9341 with SD Card Slot in arduino mega. I would like to know if it is possible to use this SD card Slot to get data logger from sensors installed in I2C. Do any of you know of a project that uses the LCD slot card itself? How much can this consume from Arduino memory?
Thanks in advance...
Cesar
Yes it is one of the example files in my IDE, I assume in yours as well. I would guess the LCD and SD are using SPI, if so you have a select problem. This response is to help you get started in solving your problem, not solve it for you. Good Luck & Have Fun! Gil
Any project can use the SD and log data from any sensor. It is only a matter of using the appropriate CS pin. The data sheet for the display or its shield should give you that. Any memory "consumed" will be the same as any other SD card.
