LCD/setCursor/print: incorrect location is used
Before my print() statements I am using a corresponding setCursor. This generally works. However, it seems as though there are times where things are printed to a different location on the screen. In some cases it is an entire row off. Other times the column is off.
I am using the stock LiquidCrystal library. Any suggestions?
Thanks!
Any suggestions?
One. Show us the code that is, or is not, working correctly.
#include <LiquidCrystal.h>
// (rs, enable, d0, d1, d2, d3, d4, d5, d6, d7);
LiquidCrystal lcd(40, 38, 22, 24, 26, 28, 30, 32, 34, 36);
[snip]
[snip]
lcd.begin(20, 4);
[snip]
[snip]
sprintf(debugLine, "X%+4d Y%+4d M%3d",
maxLat, maxLong, maxMag);
lcd.setCursor(0,3);
lcd.print(debugLine);
(I removed a bunch of code that did not seem directly relevant)
In this code, the print will some times print on line 2 (offset to another column).
Let me know if more code is needed.
Use the # button up there, and post all of your code, please.
Are maxLat, maxLong, and maxMag integers?
Without seeing your code it's hard to say what the problem is. Try printing debugLine to the serial port as well, and monitor it in the Arduino console. Perhaps the problem is the string, and not LiquidCrystal.
Code is below..
It is not totally practical to write out debug code to the serial port connected to the computer due to the fact I am interfacing with a closed source app. For basic debugging I can bypass this app by substituting my own "dummy" client. I will give this a try next but the dummy client operates minimally like the real app being interfaced to. I currently don't have another device to write out debug code.
maxLat, maxLong, and maxMag are integers. For this particular print, there recently was an erroneous line printed one row up and a few columns to the right. It seem like it generally messes up in the same way when it does happen.
There is another print line:
lcd.print("Simulator offf");
When this one messes up there is an extra "f" printed to the LCD ("Simulator off").
char debugLine [100];
int DEBUG = 0;
int prevLowPin = -1;
int prevHighPin = -1;
const int lowestPin = 2;
const int highestPin = 13;
const byte midPoint = 127;
const int limitOfMagnitude = 165;  // about 3v when used as PWM duty cycle
const int clipLED = 52;
const int magPot = 0;  // increase the force by turning potentiometer
const int magPotValue = 0;
const float magMultiplier = 0.048; // scale the pot value (0-1023) down by this amount (adds at most 50)
unsigned long lastTimeWasRecord = 0;
// these variables track "peak hold" updates to LCD
const int whenToUpdate = 4;
int numUpdates = 0;
unsigned long clipStart = 0;
int maxLat = 0;
int maxLong = 0;
int maxMag = 0;
int holdIterations = 120;
int holdLatCount = 0;
int holdLongCount = 0;
int holdMagCount = 0;
  // set pins as outputs:
  for (int thisPin =lowestPin; thisPin <= highestPin; thisPin++) {
    pinMode(thisPin, OUTPUT);
  pinMode(clipLED, OUTPUT);
  pinMode(magPot, INPUT);
  // seems like once I hooked up LCD I needed to start
  // zeroing out the vibra pins
    analogWrite(thisPin, 0);
  // cycle through for hardware check
    analogWrite(thisPin, 80);
    delay(500); // 0.5 sec
  lcd.begin(20, 4);
  blankLCD();
  // loop will be complete with one record processed
  short int latForce = 0;
  short int longForce = 0;
  int magnitude = 0;
  float angle = 0;
  int lowBound = 0;
  //int highBound = 0;
  if ( !isHeader() ) {
    // if no data in a bit turn off vibras
    if (millis() - lastTimeWasRecord > 3000 && lastTimeWasRecord != 0) {
      blankLCD();
    return;
  latForce = getByte() - midPoint;
  longForce = getByte() - midPoint;
  // Now have a lat/long pair.  Process it.  Go after if more fields
  // get added later (additional capability)
  magnitude = sqrt( sq(latForce) + sq(longForce) ) + analogRead(magPot) * 0.048;
  angle = atan2( longForce, latForce ) * 180 / M_PI;
  if (angle < 0) {
    angle = 360 + angle;
  }  // angle should be from 0 to 360 degrees
  lowBound = int (angle / 30) * 30;  // map to a angle where a vibra (every 30 deg)
  int vibraLow = angle / 30 + 2;  // turn into vibrator pin number
  int vibraHigh = (vibraLow==highestPin?lowestPin:vibraLow+1);
  float relLowBound = float ((angle - lowBound) / 30 );
  float relHighBound = 1.0 - relLowBound;
  int vibraLowDutyCycle = magnitude * (1.0 - relLowBound);
  int vibraHighDutyCycle = magnitude * (1.0 - relHighBound);
  analogWrite(vibraLow, vibraLowDutyCycle);
  analogWrite(vibraHigh, vibraHighDutyCycle);
  // less efficient then commented out approach for turning off prev vibra
    if (thisPin != vibraLow && thisPin != vibraHigh) {
  lastTimeWasRecord = millis();
  // turn off previous vibra if it wasn't turned on this pass
  /*  if (prevLowPin != vibraLow && prevLowPin != vibraHigh) {
   analogWrite(prevLowPin, 0);
   if (prevHighPin != vibraLow && prevHighPin != vibraHigh) {
   analogWrite(prevHighPin, 0);
  //prevLowPin = vibraLow;
  //prevHighPin = vibraHigh;
  if (magnitude > limitOfMagnitude) {
    if (DEBUG) {
      sprintf(debugLine, "clipped:  lat: %d  long: %d  magnitude: %d",
      latForce, longForce, magnitude);
      Serial.println(debugLine);
    magnitude = limitOfMagnitude;   //this is about 3v
    //digitalWrite(clipLED, HIGH);
    //digitalWrite(clipLED, LOW);
    lcd.setCursor(0,2);
    lcd.print("CLIP");
    clipStart = millis();
  if ( millis() - clipStart > 3000) {
    lcd.setCursor(0,2);
    lcd.print("    ");
    clipStart = 999999999;
  if (latForce > maxLat) {
    maxLat = latForce;
    holdLatCount = 0;
  else {
    holdLatCount++;
    if (holdLatCount > holdIterations) {
      maxLat = latForce;
  if (longForce > maxLong) {
    maxLong = longForce;
    holdLongCount = 0;
  else {
    holdLongCount++;
    if (holdLongCount > holdIterations) {
  if (magnitude > maxMag) {
    maxMag = magnitude;
    holdMagCount = 0;
  else {
    holdMagCount++;
    if (holdMagCount > holdIterations) {
      maxMag = magnitude;
  lcd.setCursor(0,3);
  numUpdates = 0;
  if (DEBUG) {
    sprintf(debugLine, "lat: %d (%d) long: %d (%d) mag: %d  angle: ",
    latForce, latForce+127, longForce, longForce+127, magnitude);
    Serial.print(debugLine);
    Serial.print(angle);
    sprintf(debugLine, " low: %d  vibraLow: %d relLowBound: ",
    lowBound, vibraLow, relLowBound);
    Serial.print(relLowBound);
    sprintf(debugLine, " vibraHigh: %d, vibraLowDutyCycle: %d  vibraHighDutyCycle: %d",
    vibraHigh, vibraLowDutyCycle, vibraHighDutyCycle);
  // DEL 7E 127
byte isHeader() {
  byte theByte = -1;
  if (Serial.available() == 0) {
    return 0;
  // read the incoming byte:
  theByte = Serial.read();
  if ( theByte == 0 ) {
    if (DEBUG) {
      Serial.println("got record start");
    return 1;
  else {
    if (DEBUG) {
      Serial.println("invalid record start");
    return 0;
byte getByte() {
  while (Serial.available() == 0) {
    // do nothing
  return Serial.read();
void blankLCD() {
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.print("Force Belt");
  lcd.setCursor(0,3);
  lcd.print("Simulator off");
What is the size of your display? 16x2, 20x4?
20x4.
ugh...I meant to say:
When this one messes up there is an extra "f" printed to the LCD ("Simulator offf").
I had originally thought that the extra "f" was the result of the string being printed one character over than again and the correct location. However, I am not sure this is the case.
Also, per comments in the code after the LCD was added to the Arduino I had to explicitly set the duty cycle for the vibrator pins to 0. This was because there seemed to be a spurious value on at least one of those pins that was not there before the LCD was added.
I have a 16x4 which give weird values because of the different memory allocation. But that should not be the case.
