Hi peeps,
I'm using an Arduino Uno with a LCD Shield which uses the following pins...
Pin Function
Analog 0 Button (select, up, right, down and left)
Digital 4 DB4
Digital 5 DB5
Digital 6 DB6
Digital 7 DB7
Digital 8 RS (Data or Signal Display Selection)
Digital 9 Enable
Digital 10 Backlit Control
This is declared in the code as follows;
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
I also want to use a ENC28J60 Network attachment and this uses the following pins
Wire up as following (ENC = module side):
- ENC SO -> Arduino pin 12
- ENC SI -> Arduino pin 11
- ENC SCK -> Arduino pin 13
- ENC CS -> Arduino pin 8
- ENC VCC -> Arduino 3V3 pin
- ENC GND -> Arduino Gnd pin
Now, everything's good apart from Pin 8. I am happy to cut pins if needed on my shield and remap / solder, just dont know which one's best to do.
Any advice would be most helpful. I am also running an RF reader so only really have the rest off the analogue pins and 1&2 free.
Thanks,
Steve
