LCD showing 1.45V when no voltage is mesured on UNO?
Hi
The following code is to measure RPM of a DC motor and also voltage across the armature of the machine. The problem is that , the LCD reads a 1.45V when there is no voltage being mesure or the analog input has 0V .....can someone please tell me why this is happening and what should be done to correct this??
#include <LiquidCrystal.h>
LiquidCrystal lcd(3, 5, 9, 10, 11, 12);
volatile float time = 0;
volatile float time_last = 0;
volatile int rpm_array[5] = {0,0,0,0,0};
volatile float voltage_array[5] = {0,0,0,0,0};
volatile float voltage=0;
float sensorValue;
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  //Digital Pin 2 Set As An Interrupt
  attachInterrupt(0, fan_interrupt, FALLING);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("RPM & BATT Volt");
//Main Loop To Calculate RPM and Update LCD Display
 int rpm = 0;
 int rpm_out=0;
// int sensorValue = analogRead(A0);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  //float voltage = sensorValue * (5.0 / 1023.0);
  // print out the value you read:
  //Serial.println(voltage);
 while(1){
  //Slow Down The LCD Display Updates
  delay(300);
  //Clear The Bottom Row
  lcd.setCursor(0, 1);
  lcd.print("                ");
  //Update The Rpm Count
  rpm_out=rpm*7;
  lcd.print(rpm_out);
  lcd.print(",");
  lcd.print(voltage);
  if (voltage>=4.7)
  {digitalWrite(8, HIGH);}
  {digitalWrite(8, LOW);}
  if (rpm_out>1550)
  {digitalWrite(7, HIGH);}
  {digitalWrite(7, LOW);}
//Update The RPM
  if(time > 0)
    //5 Sample Moving Average To Smooth Out The Data
      rpm_array[0] = rpm_array[1];
      rpm_array[1] = rpm_array[2];
      rpm_array[2] = rpm_array[3];
      rpm_array[3] = rpm_array[4];
      rpm_array[4] = 60*(1000000/(time*7));
    //Last 5 Average RPM Counts Eqauls....
      rpm = (rpm_array[0] + rpm_array[1] + rpm_array[2] + rpm_array[3] + rpm_array[4]) / 5;
//Capture The IR Break-Beam Interrupt
void fan_interrupt()
   time = (micros() - time_last);
   time_last = micros();
Regards
Emmanuel
Did you connect all the ground lines?
ground lines to LCD you mean? yes...
How have you confirmed it's 0V? Have you measured it with a multimeter? What does the serial monitor show when you un-comment those lines?
will check once more...and come back...
Like with any input signal, the ground of the analog voltage source must also be connected.
