LCD smartie arduino nano
HI All
I have code arduino nano using LiquidCrystal.h, i want to use module I2C for library LiquidCrystal_I2C.h, How can i fix code? Can you help me? Thank you very much
//this is my code i have it on google ^-^
// include the library code:
#include <LiquidCrystal.h>
// these constants won't change. But you can change the size of
// your LCD using them:
const int numRows = 2;
const int numCols = 16;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8,9,4,5,6,7);
// RS, RW, Enable, 4,5,6,7 (Refer to the back of your LCD for details)
// set up the LCD's number of rows and columns:
lcd.begin(numRows, numCols);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("LCD SMARTIE");
lcd.setCursor(0,1);
lcd.print("on Arduino");
byte serial_getch(){
int incoming;
while (Serial.available()==0){}
// read the incoming byte:
incoming = Serial.read();
return (byte) (incoming &0xff);
void loop(){
byte rxbyte;
byte temp;
rxbyte = serial_getch();
if (rxbyte == 254) //Matrix Orbital uses 254 prefix for commands
switch (serial_getch())
case 66: //backlight on (at previously set brightness)
// not implemented
case 70: //backlight off
// not implemented
case 71: //set cursor position
temp = (serial_getch() - 1); //get column byte
switch (serial_getch()) //get row byte
//line 1 is already set up
case 2:
temp += 0x40;
case 3:
temp += 0x14;
case 4:
temp += 0x54;
default:
lcd.command(0b10000000 + temp);
case 72: //cursor home (reset display position)
lcd.command(2);
case 74: //show underline cursor
lcd.command(0b00001110);
case 75: //underline cursor off
case 84: //block cursor off
lcd.command(0b00001100);
case 76: //move cursor left
lcd.command(16);
case 77: //move cursor right
lcd.command(20);
case 78: //define custom char
lcd.command(64 + (serial_getch() * 8)); //get+set char address
for (temp = 7; temp != 0; temp--)
lcd.print(serial_getch()); //get each pattern byte
case 83: //show blinking block cursor
lcd.command(0b00001111);
case 86: //GPO OFF
//implement later
case 87: //GPO ON
/temp = serial_getch();
if (temp == 1)
GPO1 = GPO_ON;
case 88: //clear display, cursor home
lcd.command(1);
case 152: //set and remember (doesn't save value, though)
case 153: //set backlight brightness
//not implemented
//these commands ignored (no parameters)
case 35: //read serial number
case 36: //read version number
case 55: //read module type
case 59: //exit flow-control mode
case 65: //auto transmit keypresses
case 96: //auto-repeat mode off (keypad)
case 67: //auto line-wrap on
case 68: //auto line-wrap off
case 81: //auto scroll on
case 82: //auto scroll off
case 104: //init horiz bar graph
case 109: //init med size digits
case 115: //init narrow vert bar graph
case 118: //init wide vert bar graph
default:
//all other commands ignored and parameter byte discarded
temp = serial_getch(); //dump the command code
return;
} //END OF COMMAND HANDLER
//change accented char to plain, detect and change descenders
//NB descenders only work on 5x10 displays. This lookup table works
// with my DEM-20845 (Display Elektronik GmbH) LCD using KS0066 chip.
switch (rxbyte)
//chars that have direct equivalent in LCD charmap
/* case 0x67: //g
rxbyte = 0xE7;
case 0x6A: //j
rxbyte = 0xEA;
case 0x70: //p
rxbyte = 0xF0;
case 0x71: //q
rxbyte = 0xF1;
case 0x79: //y
rxbyte = 0xF9;
*/ case 0xE4: //ASCII "a" umlaut
rxbyte = 0xE1;
case 0xF1: //ASCII "n" tilde
rxbyte = 0xEE;
case 0xF6: //ASCII "o" umlaut
rxbyte = 0xEF; //was wrong in v0.86
case 0xFC: //ASCII "u" umlaut
rxbyte = 0xF5;
//accented -> plain equivalent
//and misc symbol translation
case 0xA3: //sterling (pounds)
rxbyte = 0xED;
/* case 0xB0: //degrees symbol
rxbyte = 0xDF;
/ case 0xB5: //mu
rxbyte = 0xE4;
case 0xC0: //"A" variants
case 0xC1:
case 0xC2:
case 0xC3:
case 0xC4:
case 0xC5:
rxbyte = 0x41;
case 0xC8: //"E" variants
case 0xC9:
case 0xCA:
case 0xCB:
rxbyte = 0x45;
case 0xCC: //"I" variants
case 0xCD:
case 0xCE:
case 0xCF:
rxbyte = 0x49;
case 0xD1: //"N" tilde -> plain "N"
rxbyte = 0x43;
case 0xD2: //"O" variants
case 0xD3:
case 0xD4:
case 0xD5:
case 0xD6:
case 0xD8:
rxbyte = 0x4F;
case 0xD9: //"U" variants
case 0xDA:
case 0xDB:
case 0xDC:
rxbyte = 0x55;
case 0xDD: //"Y" acute -> "Y"
rxbyte = 0x59;
case 0xDF: //beta //mucks up LCDSmartie's degree symbol??
rxbyte = 0xE2;
*/ case 0xE0: //"a" variants except umlaut
case 0xE1:
case 0xE2:
case 0xE3:
case 0xE5:
rxbyte = 0x61;
case 0xE7: //"c" cedilla -> "c"
rxbyte = 0x63;
case 0xE8: //"e" variants
case 0xE9:
case 0xEA:
case 0xEB:
rxbyte = 0x65;
case 0xEC: //"i" variants
case 0xED:
case 0xEE:
case 0xEF:
rxbyte = 0x69;
case 0xF2: //"o" variants except umlaut
case 0xF3:
case 0xF4:
case 0xF5:
case 0xF8:
rxbyte = 0x6F;
case 0xF7: //division symbol
rxbyte = 0xFD;
case 0xF9: //"u" variants except umlaut
case 0xFA:
case 0xFB:
rxbyte = 0x75;
default:
lcd.print(rxbyte); //otherwise a plain char so we print it to lcd
return;
Hi, welcome to the forum! Would you mind changing your post according to "How to use the forum"?
About LiquidCrystal, that's harder than you might think. Not because the coding is hard, but because there are a lot of different versions of LiquidCrystal out there that are all slightly different. Se we need to know exactly which versions (LiquidCrystal and LiquidCrystal_I2C) you are using. But if most likely all you need to do is call the right constructor. So instead of
call the constructor (with correct parameters) of LiquidCrystal_I2C but do call the object 'lcd' as well.
But like I said, because of all the different versions of LiquidCrystal that can be a bit of a hell to find out. So I would suggest to use the hd44780-library by Bill Perry as an alternative :slight_smile:
For an I2C LCD display to work, the I2C address and the I2C backpack to LCD pin mapping must be correct. If the library default settings for either or both are not correct the LCD will not work. You can try to figure out the right pin mapping and use an I2C scanner to find the address, but if you install and use the hd44780 library that is done automatically by the library.
Install the hd44780 library. The hd44780 library is the best available for I2C LCDs. The library is available in the Library Manager. Go to Library Manager (in the IDE, Sketch, Include Libraries, Manage Libraries) and in the Topics dropdown choose Display and in the Filter your search box enter hd44780. Select and install the hd44780 library by Bill Perry.
The class that you want to use is the hd44780_I2Cexp class. There are examples to show how to use the library. The nice thing about the hd44780 library is that it will autodetect the I2C address and the I2C backpack to LCD pin mapping.
In the examples, there is a diagnostic sketch that will help us to help you if you still have trouble with the display. Run the diagnostic sketch and post the results.
Read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask a good question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
thank you for reply.
i have a module arduino nano uno connect lcd 20x4 with I2C i want to use them for software lcd smartie, i search code everywhere but i have not them, can you share code or somebody sharing with me. THank you.
Where do you get the idea that LCD smartie is compatible with an I2C display (post a link to where you found the reference)? The only thing that I can find on the lcd smartie site that references hd44780 LCD displays is for 8 bit parallel displays connected to a PC parallel (printer) port.
