Lcd text turning on before sensor
Hello, I am working on a project where you open a briefcase and the lcd screen starts showing text a few seconds after light has hit a sensor. (To make it look like as you open the briefcase the computer starts up.) The code for the 'boot up' works by itself, but when you add the other parts it does not. (also, the lcd is only changing the top row and not the bottom. The bottom stays 'Black Box" the whole time)
Here is the code:
#include <Wire.h>
#include <rgb_lcd.h>
int Lightsensor = A1;
int threshold;
int sensorValue;
int pressed;
rgb_lcd lcd;
const int colorR = 15 ;
const int colorG = 30;
const int colorB = 0;
const int knob = A2;
  Serial.begin (9600);
 pinMode(knob, INPUT);
  pinMode(Lightsensor, INPUT);
  threshold = 1;
    // set up the LCD's number of columns and rows:
    lcd.begin(16, 2);
    lcd.setRGB(colorR, colorG, colorB);
  sensorValue= analogRead(Lightsensor);
if(sensorValue>threshold) {
     delay(2500);
    lcd.setCursor(1, 0);
    lcd.print("Multipurpose");
    lcd.setCursor(1, 1);
    lcd.print("Black Box             ");
    delay(10);
else {
   lcd.print("               ");
    lcd.print("               ");
  if (sensorValue > 12 && sensorValue <337)
sensorValue = analogRead(knob);
Serial.print("KnobValue = ");  // Say Knob Value =
Serial.println(sensorValue);
    lcd.setCursor(0, 0);
   lcd.print(" Radio Pulse  ");
    lcd.print("Detector");
  if (sensorValue < 12 )
    lcd.print(" Multipurpose  ");
    lcd.print("Black Box");
  if (sensorValue > 337 && sensorValue <674)
    lcd.print("Code Cracker ");
    lcd.print("        ");
  if (sensorValue > 674 && sensorValue <1011)
    lcd.print("!Self Distruct!");
The problem is here
    if (sensorValue > 674 && sensorValue < 1011)
You forgot the curly brackets around the dependant code
ok! Thank you... will that fix the light sensor problem? I do not want any text to show up until the light sensor is over a certain point.
Also... just to make sure... where should the brackets be added?
Then don't print anything unless the light sensor is over a certain point.
isn't that the
     delay(2500);
    delay(10);
else {
   lcd.print("               ");
    lcd.print("               ");
Fix the problem that I pointed out and come back if you have any remaining problems
Can you say specifically where to put the brackets ?It still isn't working
Put the brackets round the code that you want to run when
is true, just like the other tests and code blocks in your sketch
When I do that the text changes depending on light but it is all jumbled up.
Post your latest code in a new post
#include <Wire.h>
int threshold;
int sensorValue;
int pressed;
rgb_lcd lcd;
  threshold = 1;
    lcd.begin(16, 2);
     delay(2500);
    delay(10);
else {
   lcd.print("               ");
    lcd.print("               ");
    lcd.print("        ");
I do not really care about the bottom line not changing I just need the display to show no text when there is no light and it to display the prompt with the corresponding knob values.
At what value of sensorValue do you want to start displaying text ?
At the moment you have threshold set to 1 so any value greater than 1 will display something
The sketch also has a number of redundant { } pairs which serve to confuse anyone reading the code and I just noticed that you have removed the brackets around most of the dependent code for your tests of sensorValue. Why did you do that ?
I have cleaned it up and now have this
the text works but I am getting a 'else' without previous 'if' for the light sensor part
#include <Wire.h>
int threshold;
int sensorValue;
int pressed;
rgb_lcd lcd;
  threshold = 50;
    lcd.begin(16, 2);
   lcd.print(" black box 101 ");
  if (sensorValue > 12 && sensorValue <337){
   lcd.print(" Radio pulse ");
    lcd.print("Detector ");
   else if (sensorValue < 12 ){
  else if (sensorValue > 337 && sensorValue <674){
    lcd.print("           ");
 else {
  sensorValue = analogRead(Lightsensor);
  if (sensorValue > threshold)
Why aren't the code blocks for the if and else in curly brackets ?
