LCD Touch Buttons
My goal is to assign a function (Logging_Function()) to a start/stop button.
For some reason using "TS_Point p = ts.getPoint()" is stopping the "void loop" I think since the time and analog values are not refreshing.
I am pretty much a beginner so please try and keep it simple. Thank you.
#include <Adafruit_GFX.h>    // LCD GUI library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include "RTClib.h"          //RTC Library
#include <MCUFRIEND_kbv.h>   //LCD Library
#include <SPI.h>             //SPI Library
#include <SD.h>              //SD Module Library
#include "TouchScreen.h"
#include <stdint.h>
#include <Wire.h>      // this is needed even tho we aren't using it
#include <Adafruit_STMPE610.h>
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
#define TS_MINX 150
#define TS_MINY 150
#define TS_MAXX 3800
#define TS_MAXY 4000
const int chipSelect = 4;
char daysOfTheWeek[7][12] = {"Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"};
#define YP A3  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 9   // can be a digital pin
#define XP 8   // can be a digital pin
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define STMPE_CS 8
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
// Assign human-readable names to some common 16-bit color values:
#define BLACK       0x0000      /*   0,   0,   0 */
#define NAVY        0x000F      /*   0,   0, 128 */
#define DARKGREEN   0x03E0      /*   0, 128,   0 */
#define DARKCYAN    0x03EF      /*   0, 128, 128 */
#define MAROON      0x7800      /* 128,   0,   0 */
#define PURPLE      0x780F      /* 128,   0, 128 */
#define OLIVE       0x7BE0      /* 128, 128,   0 */
#define LIGHTGREY   0xC618      /* 192, 192, 192 */
#define DARKGREY    0x7BEF      /* 128, 128, 128 */
#define BLUE        0x001F      /*   0,   0, 255 */
#define GREEN       0x07E0      /*   0, 255,   0 */
#define CYAN        0x07FF      /*   0, 255, 255 */
#define RED         0xF800      /* 255,   0,   0 */
#define MAGENTA     0xF81F      /* 255,   0, 255 */
#define YELLOW      0xFFE0      /* 255, 255,   0 */
#define WHITE       0xFFFF      /* 255, 255, 255 */
#define ORANGE      0xFDA0      /* 255, 180,   0 */
#define GREENYELLOW 0xB7E0      /* 180, 255,   0 */
#define PINK        0xFC9F
RTC_DS3231 rtc;
MCUFRIEND_kbv tft;
  tft.reset();
  uint16_t identifier = tft.readID();
  if(identifier==0x0101)
      identifier=0x9341;
      Serial.println(F("Found 0x9341 LCD driver"));
  tft.begin(identifier);
  tft.setRotation(1);
  tft.fillScreen(BLACK);
  tft.fillRect(0, 0, 320, 25, NAVY);
  rtc.begin(); // Initialize the rtc object
  tft.fillRect(100, 0, 200, 25, NAVY);
  tft.setTextColor(ORANGE);
  tft.setCursor(100, 0);
  tft.print("Initializing RTC");
  if (! rtc.begin()) {
    tft.setTextColor(RED);
    tft.print("RTC Error");
  else{
    tft.setTextColor(GREEN);
    tft.print("RTC Initialized");
  if (rtc.lostPower()) {
    Serial.println("RTC lost power, let's set the time!");
    tft.print("Connect to PC to Sync Time");
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  tft.print("Initializing SD");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    tft.print("SD Error");
  else{
    tft.print("SD Initialized");
/*  if (!ts.begin()) {
    tft.print("Touch Screen Error");
    while (1);
  else{
    tft.print("Touch Screen Initialized");
void RTC_Display(){
  tft.fillRect(250, 0, 75, 25, NAVY);
  DateTime now = rtc.now();
  tft.setTextColor(WHITE);
  tft.setTextSize(1);
  tft.setCursor(0, 0);
  tft.print(now.day(), DEC);
  tft.print("-");
  tft.print(now.month(), DEC);
  tft.print("-");
  tft.print(now.year(), DEC);
  tft.setCursor(0, 15);
  tft.print(daysOfTheWeek[now.dayOfTheWeek()]);
  tft.setCursor(270, 0);
  tft.print(now.hour(), DEC);
  tft.print(":");
  tft.print(now.minute(), DEC);
  tft.print(":");
  tft.print(now.second(), DEC);
void Logging_Function(){
  String dataString = "";
  float ScalingFactor_Press = 0.5;
  float ScalingFactor_Flow = 0.5;
  float ScalingFactor_Temp = 0.5;
  float Press = analogRead(A5);
  Press = Press - 335;
  Press = Press*ScalingFactor_Press/1000;
  float Flow = analogRead(A6);
  Flow = Flow - 360;
  Flow = Flow*ScalingFactor_Flow/1000;
  float Temp = analogRead(A7);
  Temp = Temp - 320;
  Temp = Temp*ScalingFactor_Temp/1000;
  dataString += String(",Pressure:");
  dataString += String(Press);
  dataString += String(",Flow Rate:");
  dataString += String(Flow);
  dataString += String(",Temperature:");
  dataString += String(Temp);
    tft.fillRect(100, 0, 150, 25, NAVY);
    tft.print("SD Error on Logging");
  else{
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (dataFile) {
    dataFile.print("Logged ON: ");
    dataFile.print(now.year(), DEC);
    dataFile.print("-");
    dataFile.print(now.month(), DEC);
    dataFile.print(now.day(), DEC);
    dataFile.print(" at :");
    dataFile.print(now.hour(), DEC);
    dataFile.print(":");
    dataFile.print(now.minute(), DEC);
    dataFile.print(now.second(), DEC);
    dataFile.print(" -- ");
    dataFile.println(dataString);
    dataFile.close();
    tft.setTextColor(YELLOW);
    tft.print("Log Value Saved");
  else{
void Logging_Display(){
  tft.setCursor(20, 75);
  tft.print("PRESSURE");
//  tft.fillRect(90, 65, 150, 25, BLACK);
  tft.fillRect(90, 65, 150, 25, GREEN);
  tft.setTextColor(BLACK);
  tft.setCursor(125, 75);
  tft.print(Press);
  tft.print(" BAR");
  tft.setCursor(20, 100);
  tft.print("FLOW RATE");
//  tft.fillRect(90, 90, 150, 25, BLACK);
  tft.fillRect(90, 90, 150, 25, YELLOW);
  tft.setCursor(125, 100);
  Flow = Flow - 360;
  tft.print(Flow);
  tft.print(" LPM");
  tft.setCursor(20, 125);
  tft.print("TEMPERATURE");
//  tft.fillRect(90, 115, 150, 25, BLACK);
  tft.fillRect(90, 115, 150, 25, RED);
  tft.setCursor(125, 125);
  Temp = Temp - 320;
  tft.print(Temp);
  tft.print(" C");
void Home_Buttons(){
  tft.fillRect(120,200,120,40,CYAN);
  tft.drawRect(120,200,120,40,WHITE);
  RTC_Display();
  Logging_Display();
  Home_Buttons();
  if (ts.bufferEmpty()){
    return;}
  TS_Point p = ts.getPoint();
//    Serial.println(p.x);
//    Serial.println(p.y);
//    p.x=map(p.x, TS_MINX, TS_MAXX,0,tft.width());
//    p.y=map(p.y, TS_MINY, TS_MAXY,0,tft.height());
//    if(p.x>120 && p.x<240){
//      if(p.y>200 && p.y<240){
//        Logging_Function();
This looks dangerous... where does loop() return to?
  RTC_Display();
  Logging_Display();
  Home_Buttons();
  if (!ts.bufferEmpty()){
//    TS_Point p = ts.getPoint();
made a minor change to remove that 'return' but still when the "TS_Point p = ts.getPoint();" is commented the void loop is running but when it is not commented, the first 3 functions are called only once. I know because the seconds from the RTC is visible on the LCD and it refreshes every loop.
Let's confirm where it stops with a couple of debug lines...
Serial.println("before call");
Serial.println("after call");
