LCD Trouble
Hi I am a new to Arduino and my lcd does not seem to work. I have double checked all the connections are right, and when the Arduino is powered on, there is only a very faint light on the LCD screen. Does anyone know the common problems to watch out for when using LCDs. Thanks,
You could have a problem with your wiring, a problem with your code, or (not likely) a bad LCD module.
Don
Where can I go to get a diagram of a wiring board, just so I can make sure I am doing it right?
LCD displays compatible with Hitachi HD44780 driver
Mine is 16x2
pin 1 gnd ----arduino gnd
pin 2 vcc(positive)---arduino 5v pin
pin 3 vee(contrast) ---- a 10k pot middle pin
the other two pins one to arduino 5v pin the other to arduino gnd
pin 4 rs pin(register select) -----pin 12 on your arduino(you can use any other pins)
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
change the pins according to the orders
pin 5 rw pin(read/write) (connect to gnd to write) ---gnd(you write to the lcd)
pin 6 enable en pin as above
4 bit mode ----- (as above)
15 lcd led +(positive)pin (if you have no resistor on lcd u need to use a resistor)
16 lcd led -(ground)pin -------arduino ground(gnd)
if you are connecting everything on a breadboard make sure the wires are in position
if u solder a header to the lcd make sure the joints are ok
if u have a multitester use it to make sure pins are not soldered together
do not forget to turn the 10k pot to see what you can see on the lcd
just run the lcd hello world example to make sure your lcd is working
gl
