LCD turns white
Hello everyone.
I have problem with my LCD touchscreen shield turns white after I click button on it.
I am using Arduino Uno and 2.4" TFT LCD display with ILI9341 driver.
The code i am making is keypad with password, but not finished after this problem occur.
Code:
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
#define MINPRESSURE 200
#define MAXPRESSURE 1000
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
const int XP=8,XM=A2,YP=A3,YM=9;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
int x, y;
  uint16_t ID = tft.readID();
  tft.begin(ID);
  tft.setRotation(1);
  tft.fillScreen(BLACK);
  drawNumpad();
  tft.setTextSize(3);
  tft.setCursor(190, 14);
  tft.setTextColor(WHITE);
  TSPoint p = ts.getPoint();
  if(p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    x = map(p.y, 74, 897, 0, 320);
    y = map(p.x, 903, 127, 0, 240);
    if(x >= 0 and x <= 60 and y >= 0 and y <= 60){
      Serial.println("1");
      tft.print("1");
    if(x >= 60 and x <= 120 and y >= 0 and y <= 60){
      Serial.println("2");
      tft.print("2");
    if(x >= 120 and x <= 180 and y >= 0 and y <= 60){
      Serial.println("3");
      tft.print("3");
    if(x >= 0 and x <= 60 and y >= 60 and y <= 120){
      Serial.println("4");
      tft.print("4");
    if(x >= 60 and x <= 120 and y >= 60 and y <= 120){
      Serial.println("5");
      tft.print("5");
    if(x >= 120 and x <= 180 and y >= 60 and y <= 120){
      Serial.println("6");
      tft.print("6");
    if(x >= 0 and x <= 60 and y >= 120 and y <= 180){
      Serial.println("7");
      tft.print("7");
    if(x >= 60 and x <= 120 and y >= 120 and y <= 180){
      Serial.println("8");
      tft.print("8");
    if(x >= 120 and x <= 180 and y >= 120 and y <= 180){
      Serial.println("9");
      tft.print("9");
    if(x >= 0 and x <= 60 and y >= 180 and y <= 240){
      Serial.println("*");
      tft.print("*");
    if(x >= 60 and x <= 120 and y >= 180 and y <= 240){
      Serial.println("0");
      tft.print("0");
    if(x >= 120 and x <= 180 and y >= 180 and y <= 240){
      Serial.println("#");
      tft.print("#");
void drawNumpad(){
  tft.fillRect(0, 0, 180, 240, BLUE);
  tft.fillRect(0, 180, 60, 60, RED);
  tft.fillRect(120, 180, 60, 60, RED);
  tft.drawRect(0, 0, 60, 60, WHITE);
  tft.drawRect(60, 0, 60, 60, WHITE);
  tft.drawRect(120, 0, 60, 60, WHITE);
  tft.drawRect(0, 60, 60, 60, WHITE);
  tft.drawRect(60, 60, 60, 60, WHITE);
  tft.drawRect(120, 60, 60, 60, WHITE);
  tft.drawRect(0, 120, 60, 60, WHITE);
  tft.drawRect(60, 120, 60, 60, WHITE);
  tft.drawRect(120, 120, 60, 60, WHITE);
  tft.drawRect(0, 180, 60, 60, WHITE);
  tft.drawRect(60, 180, 60, 60, WHITE);
  tft.drawRect(120, 180, 60, 60, WHITE);
  tft.setTextSize(4);
  tft.setCursor(20, 14);
  tft.println("1");
  tft.setCursor(20, 74);
  tft.println("4");
  tft.setCursor(20, 134);
  tft.println("7");
  tft.setCursor(20, 194);
  tft.println("*");
  tft.setCursor(80, 14);
  tft.println("2");
  tft.setCursor(80, 74);
  tft.println("5");
  tft.setCursor(80, 134);
  tft.println("8");
  tft.setCursor(80, 194);
  tft.println("0");
  tft.setCursor(140, 14);
  tft.println("3");
  tft.setCursor(140, 74);
  tft.println("6");
  tft.setCursor(140, 134);
  tft.println("9");
  tft.setCursor(140, 194);
  tft.println("#");
If something else will be needed then write down.
Have you tested your LCD with library example code?
Please run the library examples first. Study the code. e.g. from button_simple.ino
int pixel_x, pixel_y;     //Touch_getXY() updates global vars
bool Touch_getXY(void)
    pinMode(YP, OUTPUT);      //restore shared pins
    pinMode(XM, OUTPUT);
    digitalWrite(YP, HIGH);   //because TFT control pins
    digitalWrite(XM, HIGH);
    bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
    if (pressed) {
        pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
        pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
    return pressed;
or from Touch_Shield_new.ino
    uint16_t xpos, ypos;  //screen coordinates
    tp = ts.getPoint();   //tp.x, tp.y are ADC values
    // if sharing pins, you'll need to fix the directions of the touchscreen pins
    // we have some minimum pressure we consider 'valid'
    // pressure of 0 means no pressing!
    if (tp.z > MINPRESSURE && tp.z < MAXPRESSURE) {
This is a "feature" of shared data pins. The TouchScreen.h library does not restore the pins after a ts.getPoint(); call.
David.
Thank you david, now it works!
Ive added:
and it works.
You don't actually need the digitalWrite() statements.
Most versions of TouchScreen will leave YP, XM "high" even if they don't restore the pinMode()
David.
