LCD using Higher Pins not working
Hello All,
I am trying to use the example program to display data one a LCD using higher digital pins
If i use the default pins in the example everything works with no problem.
Thank you,
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(16, 17, 23, 25, 27, 29);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
Anyone out there have this problem.
Thank you
