LCD Value does not getting updatet after 5 seconds ??
Hey everyone,
got a littler problem with my project. I want to display the rpm on a LCD.
I have a Hall Sensor with works fine. The whole programm works and the RPM gets displayed very well.
But: After some time running (around 5 seconds) the value on the Display does not get updatet anymore. i don't find a solution
Seems that the arduino fails or something..
Please help
Regards Phil
 // read RPM
 #include <LiquidCrystal.h>
 int half_revolutions = 0;
 int rpm = 0;
 unsigned long lastmillis = 0;
 int led = 13;
 LiquidCrystal lcd(12, 11, 5, 4, 3, 8);
 void setup(){
 attachInterrupt(0, rpm_fan, FALLING);
 pinMode(led, OUTPUT);
 lcd.begin(16, 2); // set up the LCD's number of columns and rows:
 void loop(){
 if (millis() - lastmillis == 333){ //Uptade every 1/3 second, this will be equal to reading  1/3 frecuency (Hz).
 detachInterrupt(0);//Disable interrupt when calculating
 rpm = half_revolutions * 6; // Convert frecuency to RPM, note: 6 because 1/3 frequency and multiplied by 2 because of half recolutions 6 = 2 * 3.
if(rpm < 10){
  lcd.clear();
  lcd.setCursor(0, 2);
  lcd.print(rpm);
if(rpm > 10){
  lcd.print(rpm);
if(rpm > 100){
  lcd.clear();
  lcd.print(rpm);
half_revolutions = 0; // Restart the RPM counter
lastmillis = millis(); // Uptade lasmillis
attachInterrupt(0, rpm_fan, FALLING); //enable interrupt
   } } // this code will be executed every time the interrupt 0 (pin2) gets low.
 void rpm_fan(){
  half_revolutions++;
variables used in interrupt service routines need to be declared volatile. And an int might be overflowing, try it with long instead.
volatile int half_revolutions = 0;
Hey,
i changed to volatile and long... But the problem is still aviable. hmm
Regards Phil
It's probably not a good idea to check that the time interval is exactly 333 milliseconds. Try replacing
with
if (millis() - lastmillis >= 333)
I don't know your hardware set-up so I tried using your IF loop condition in this simple code
{  Serial.begin(9600);
{  if (millis() - lastmillis >= 333)
  {   Serial.println(lastmillis);
When I used "==" instead of ">=", it latched up at just under 13 seconds. I'm not sure why I didn't duplicate your 5 seconds. Maybe it's due to differences in the test configuration or maybe your estimate wasn't precise. I know there was no need for precision here.
While
there is no need to keep attaching and detaching interrupts.
See:-
http://arduino.cc/en/Reference/Interrupts#.Uwl_rl6prdU
Hey guys,
problem solved! it was the =>
:slight_smile: Thanks to you all!
