LCD VSS Fried?!?!
I think I fried my LCS VSS connection, It accidentally contacted what I think was a power connection and it made the LCD start to flash and freak out and I immediately removed the contacting connection from the VSS connection and now when I try it, it doesn't work. HELP!!!! PLEASE!!!!
If you fried the LCD, there's nothing that can be done about it.
I mean it still turns on but It seems it doesn't receive info.
Vss is the ground pin. If you put a voltage on there that's bigger than the Vdd, there is a good chance that you blow the controller chip.
As it's impossible to say what you exactly did ("what I think was a power connection"), I would consider it a lost case.
