'lcd' Was not declared in this scope.
Hello!
I recently started making a keypad door lock and decided to add an lcd. I keep getting this error and i don't know why.
Error:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Users\ephra\OneDrive\Documents\Arduino\keypadlock\keypadlock.ino: In function 'void setup()':
keypadlock:9:3: error: 'lcd' was not declared in this scope
   lcd.begin(16, 2);                          // put your LCD parameters here
C:\Users\ephra\OneDrive\Documents\Arduino\keypadlock\keypadlock.ino: At global scope:
C:\Users\ephra\OneDrive\Documents\Arduino\keypadlock\keypadlock.ino:17:18: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
 char* password = "6543"; //We set the password. In this case „123“
keypadlock:47:6: error: redefinition of 'void setup()'
C:\Users\ephra\OneDrive\Documents\Arduino\keypadlock\keypadlock.ino:7:6: note: 'void setup()' previously defined here
C:\Users\ephra\OneDrive\Documents\Arduino\keypadlock\keypadlock.ino: In function 'void setLocked(int)':
keypadlock:106:3: error: a function-definition is not allowed here before '{' token
keypadlock:115:1: error: 'lcd' was not declared in this scope
 lcd.print("Please Enter The Passcode.");
exit status 1
option enabled in File -> Preferences.
Code:
#include <Keypad.h> //Include Keypad and servo library
#include <Wire.h>
#include <LiquidCrystal.h>
#include <Servo.h>
Servo servoblue; //The servo is called „servoblue“ from now on
int position = 0;
const byte ROWS = 4; //In this two lines we define how many rows and columns
const byte COLS = 3; //our keypad has
char keys[ROWS][COLS] = { //The characters on the keys are defined here
{'#', '0', '*'},
{'9', '8', '7'},
{'6', '5', '4'},
{'3', '2', '1'}
byte rowPins[ROWS] = {5, 6, 7, 8}; //The connection with the arduino is
byte colPins[COLS] = {2, 3, 4}; //listed here
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int redLED = 12; //The red LED is connected to pin 12
int greenLED = 13; //The green LED is connected to pin 13
pinMode(redLED, OUTPUT); //The LEDs are defined as Output
pinMode(greenLED, OUTPUT);
servoblue.attach(11); //The servo is connected to pin 11
setLocked(true);
char key = keypad.getKey();
if (key == '*' || key == '#')
position = 0;
setLocked(true);
if (key == password[position])
position ++;
if (position == 4) //This part defines how many digits our code will have.In this case we have 3 digits //(123).
setLocked(false);
delay(100);
void setLocked(int locked)
if (locked) // If the lock is closed..
digitalWrite(redLED, HIGH); //..the red LED should light up..
digitalWrite(greenLED, LOW); //..the green LED not..
servoblue.write(90); //and the servo should turn to a 90 degree position.
else //if the lock is open..
#include <Wire.h>
digitalWrite(redLED, LOW); //..the red LED should be off..
digitalWrite(greenLED, HIGH); //..and the green LED should light up..
servoblue.write(0); //..and the servo should turn to a 0 degree position.
What are those #includes doing scattered around the code? They do not belong.
I don't see where you declare a lcd object or a lcd.begin(). Look at the examples in the LiquidCrystal library.
To:
char password[] = "6543";
char* is a pointer. Pointers only hold addresses (integer numbers). A string is not a number.
Excellent first post, karma.
