LCD white box at angle
Hello all,
I stumbled into an issue when connecting my LCD screen to my Arduino Mega 2560. When activated my lcd will only show white boxes unless held at an angle. Is this a wiring error or a coding error? and how can I fix this?
Thanks
#include <LiquidCrystal.h>
#include <Keypad.h> //libraries
static int count = 0; //variable used as first number
unsigned long lastTime = millis();
unsigned long wait = 10000;
LiquidCrystal lcd(24,26,28,30,32,34);
const byte ROWS = 4;
const byte COLS = 4;
bool blinking = false;
int buttonState=0;
int lastButtonState=0;
int buttonPushCounter =0;
int memory;
  void partLoc(){
      lcd.setCursor(7,1);
  void fabLoc(){
      lcd.setCursor(11,0);
  void clearScreen(){
      lcd.print("     ");
  void countUp(){
      count++;
      partLoc();
      clearScreen();
        partLoc();
      lcd.print(count);
        for (int i = 0; i <= 16; i++) {
          blinking=false;
            lcd.setCursor(i,1);
          tone(52,2200);
          delay(100);
          noTone(52);
  void countDown(){
      if(count!=0){
          count--;
          partLoc();
        clearScreen();
          partLoc();
        lcd.print(count);
            partLoc();
            lcd.print(count);
            blinking=false;
              lcd.setCursor(i,1);
                tone(52,2100);
          delay(100);
          noTone(52);
char hexaKeys [ROWS][COLS] ={
        {'1','2','3','A'},
        {'4','5','6','B'},
        {'7','8','9','C'},
        {'*','0','#','D'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  analogWrite(22,75);
  pinMode (52,OUTPUT);
  pinMode(51, OUTPUT);
  pinMode(13,INPUT);
  lcd.begin(16, 2);
  lcd.print("Fab Cell #");
  lcd.setCursor(0,1);
  lcd.print("Part #");
  lcd.blink();
void loop(){
  int sensor = digitalRead(53);
  unsigned long timeNow = millis();
  buttonState = digitalRead(53);
  if (buttonState != lastButtonState) {
    if (buttonState == 1)  {
      buttonPushCounter++;
      //Serial.println("off");
      if (timeNow - lastTime > wait){ // adds delay after the count up but allows for input during the delay.  delay will not stop the rest of the program from running
      countUp();
      Serial.println(count);
      lastTime=timeNow;
  lastButtonState = buttonState;
  char customKey = customKeypad.getKey();
  if (blinking){
    lcd.blink();
  //Switchcase Statements
  switch (customKey){
    case 'C':
      countUp();
    case 'D':
    countDown();
    case 'B':
      fabLoc();
      clearScreen();
      fabLoc();
      blinking = true;
          tone(52,2200);
          delay(100);
          noTone(52);
  // Allows button input from buttons 0 - 9
  if ((customKey>='0') && (customKey <= '9')){
      lcd.print(customKey);
          blinking=false;
            lcd.setCursor(i,1);
          tone(52,2000);
          delay(100);
          noTone(52);
  //When A is pressed displays the most recently cleared number
    if (customKey=='A'){
        blinking=false;
          lcd.setCursor(i,0);
        blinking=false;
          lcd.setCursor(i,1);
          Serial.println(memory);
          lcd.setCursor(9,0);
          lcd.print(memory);
          delay(3000);
          lcd.setCursor(7,0);
          lcd.print("    ");
  //When # is pressed the count resets
    if (customKey=='#'){
      memory = count;  //stores the cleared value
      count=0;
      Serial.println("reset");
      lcd.setCursor(6,1);
      lcd.print("     ");
      partLoc();
      lcd.print(count);
      blinking=false;
        lcd.setCursor(i,1);
         tone(52,1200);
          delay(100);
          noTone(52);
try to adjust the contrast potentiometer (you might need a small screwdriver, if you use a metallic one, don't do this whilst powered), it's likely set too high
if you have an I2C backpack it looks like this
I do not have an i2c backpack, is this required? I also do not have a potentiometer.
Follow this LCD setup guide from Adafruit (one of many on line), which includes how to set up and use the contrast potentiometer. https://cdn-learn.adafruit.com/downloads/pdf/adafruit-arduino-lesson-11-lcd-displays-1.pdf
The pot is not always necessary, sometimes it is satisfactory to connect Vo (the display contrast adjustment pin 3) to GND.
If a forum member drops in to tell you that the contrast adjustment is incorrectly wired, you can ignore them.
It’s not (just makes life easier) but indeed follow one of the setup guide.
