LCD+ Wireless Radio Transmitter+encryption/decryption
help me please witch decryption text.
i have two arduino.
First was transmit and the second is receiver.
I realized
transmit-->>encryption-->>send-->>recive(encrypted)-->>decryption-->>Send to Screen Receiver
remains only decryption.
function aes128_dec_single(key, data);
but I can not understand how to get full buf for use aes128_dec_single(key, data);
Thank you in advance for your help..
transmit
#include <VirtualWire.h>
#include <AESLib.h>
  vw_setup(2000);   // Bits per sec
  Serial.begin(57600);
  uint8_t key[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
  char msg[] = "testtesttesttest";
  aes128_enc_single(key, msg);
  vw_send((uint8_t *)msg, 16);
  vw_wait_tx(); // Wait until the whole message is gone
receiver
#include <Wire.h>
#include <AESLib.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
  lcd.begin();
  lcd.backlight();
    vw_setup(2000);
    vw_rx_start();       // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
  int i;
   lcd.clear();
  Serial.print("Got: ");
  lcd.print("Got: ");
  for (i = 0; i < buflen; i++)
     Serial.write(buf[i]);
        lcd.write(buf[i]);
    lcd.clear();
    lcd.print("wait ");
but I can not understand how to get full buf[ i ]
buf[ i ] is ONE element of the array. buf is the whole array. You get that here:
VirtualWire will receive a message of the same length as the message you send.
You may need to change the default buffer size in VirtualWire.
how to get the entire array ? buf
then I just do aes128_dec_single(key, data);
I got full buf , only for output to Screen but not for use
Serial.write(buf,16);
That statement writes 16 bytes.
You will have to do a better job of explaining the problem you are having.
if I use
aes128_dec_single(key, buf);
Serial.print("decrypted:");
Serial.write(buf);
i have many errors
reciwedec.ino: In function 'void loop()':
reciwedec:37: error: call of overloaded 'write(uint8_t [30])' is ambiguous
reciwedec.ino:37:17: note: candidates are:
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:224:0,
                 from C:\Program Files (x86)\Arduino\libraries\VirtualWire/VirtualWire.h:146,
                 from reciwedec.ino:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:124:20: note: virtual size_t HardwareSerial::write(uint8_t) <near match>
     virtual size_t write(uint8_t);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:124:20: note:   no known conversion for argument 1 from 'uint8_t [30] {aka unsigned char [30]}' to 'uint8_t {aka unsigned char}'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:125:19: note: size_t HardwareSerial::write(long unsigned int) <near match>
     inline size_t write(unsigned long n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:125:19: note:   no known conversion for argument 1 from 'uint8_t [30] {aka unsigned char [30]}' to 'long unsigned int'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:126:19: note: size_t HardwareSerial::write(long int) <near match>
     inline size_t write(long n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:126:19: note:   no known conversion for argument 1 from 'uint8_t [30] {aka unsigned char [30]}' to 'long int'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:127:19: note: size_t HardwareSerial::write(unsigned int) <near match>
     inline size_t write(unsigned int n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:127:19: note:   no known conversion for argument 1 from 'uint8_t [30] {aka unsigned char [30]}' to 'unsigned int'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:128:19: note: size_t HardwareSerial::write(int) <near match>
     inline size_t write(int n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:128:19: note:   no known conversion for argument 1 from 'uint8_t [30] {aka unsigned char [30]}' to 'int'
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:224,
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:49:12: note: size_t Print::write(const char*) <near match>
     size_t write(const char *str) {
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:49:12: note:   no known conversion for argument 1 from 'uint8_t [30] {aka unsigned char [30]}' to 'const char*'
why?
plz help.
how to obtain data for use in
Post the entire program, using code tags ("</>" button). The error messages are meaningless, except, of course, this line suggesting nonsensical code:
#include <Wire.h>
#include <AESLib.h>
 lcd.begin();
 lcd.backlight();
   vw_setup(2000);
 int i;
  lcd.clear();
 lcd.print("Got: ");
       lcd.write(buf[i]);
   lcd.clear();
   lcd.print("wait ");
This full program receiver.
I recive
Got: Y±§Ъm\ЊЇЎЪщCJК<‚ - data that must decipher
if I use aes128_dec_single(key, buf);
Serial.write(buf);
I get an error :frowning:
Serial.write(buf);
I get an error
The compiler is telling you what the problem is. The write() method of the HardwareSerial class (that Serial is an instance of) is overloaded. One version takes ONE byte. The other takes and array of bytes AND a number defining the size of the array.
Thanks a lot
Serial.write(buf,buflen);
Got: testtesttesttest :wink:
