LCD won't display ethernet.begin()
hello,
ethernet.begin()
I deleted it.
Adding doesn't work.
this is my code
#include <SPI.h>
#include <Ethernet.h>
#include <LiquidCrystal.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Setting MAC Address
#define DHTPIN 8
#define DHTTYPE DHT11
LiquidCrystal lcd( 11, 12, 5, 4, 3, 2);
DHTdht(DHTPIN,DHTTYPE);
float humidityData;
float temperatureData;
IPAddress server(10,0,0,30);
IPAddress ip(10, 20, 0, 95);
IPAddress gateway(10, 20, 0, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress myDns(8, 8, 8, 8);
EthernetClient client;
/* Setup for Ethernet and RFID */
  dht.begin();
  lcd.begin(16,2);
  **Ethernet.begin(mac, ip, gateway, subnet, myDns);**
/* Infinite Loop */
void loop(){
  humidityData = dht.readHumidity();
  temperatureData = dht.readTemperature();
  Sending_To_phpmyadmindatabase();
  delay(1000); // interval
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("ID01 TEMP:");
  lcd.print((float)temperatureData);
  lcd.print("C");
  lcd.setCursor(0,1);
  lcd.print("ID01 NEM:");
  lcd.print(humidityData);
  lcd.print(" %");
  void Sending_To_phpmyadmindatabase() //CONNECTING WITH MYSQL
   if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    Serial.print("GET /testcode/dht2.php?humidity=");
    client.print("GET /testcode/dht2.php?humidity="); //YOUR URL
    Serial.println(humidityData);
    client.print(humidityData);
    client.print("&temperature=");
    Serial.println("&temperature=");
    client.print(temperatureData);
    Serial.println(temperatureData);
    client.print(" "); //SPACE BEFORE HTTP/1.1
    client.print("HTTP/1.1");
    client.println();
    client.println("Host: 10.0.0.30");
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
I'm waiting for your help
Adding
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
some of these pins are also used for SPI (e.g. 11, 12).
SPI is used for the Ethernet Shield
4 is used for the SD Card if available on the Ethernet Shield.
Check ALL pins your Ethernet Shield is using.
Don't use them for the LCD.
I have attached the wiring diagram, can you check it?
Hello mehmetmcan
Welcome to the worldbest Arduino forum ever.
This is a nice project to get started.
Keep it simple and stupid firstly.
Follow the example code that comes with the library or
run some tutorials for the hardware selected.
If you are happy with the results of the tutorials you can merge these to your project.
Çözüldü problem
Solved problem
