i made an code for a scale and it goes to 9 kilometers. I transferred the centimeters to kilograms in manually but the arduino always says is 9 Kilogram
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
int trigPin = 9; // TRIG pin
int echoPin = 8; // ECHO pin
int buttonpin = 2;
float duration_us, distance_cm;
Serial.begin(9600); //Serial baud rate
lcd.begin (16, 2);
lcd.init(); // initialize the lcd
lcd.backlight();
lcd.home ();
lcd.print(distance_cm);
//delay(2000);
//lcd.clear();
// configure the trigger pin to output mode
pinMode(trigPin, OUTPUT);
// configure the echo pin to input mode
pinMode(echoPin, INPUT);
pinMode(buttonpin, INPUT_PULLUP);
// generate 10-microsecond pulse to TRIG pin
digitalWrite(trigPin, HIGH);
delayMicroseconds(10000);
digitalWrite(trigPin, LOW);
// measure duration of pulse from ECHO pin
duration_us = pulseIn(echoPin, HIGH);
// calculate the distance
distance_cm = 0.017 * duration_us;
if(digitalRead(buttonpin) ==LOW)
delay(30);
if( distance_cm >= 19.90){
lcd.clear();
lcd.print("0 kilogram");
if(18.00<=distance_cm<19.90){
lcd.clear();
lcd.print("500 gram");
} if(17.00<=distance_cm<18.00){
lcd.clear();
lcd.print("1.500 kilogram");}
if(16.00<=distance_cm<17.00){
lcd.clear();
lcd.print("2 kilogram");}
if(15.00<=distance_cm<16.00){
lcd.clear();
lcd.print("2.5 kilogram");}
if(14.00<=distance_cm<15.00){
lcd.clear();
lcd.print("3 kilogram");}
if(13.00<=distance_cm<14.00){
lcd.clear();
lcd.print("3.5 kilogram");}
if(12.00<=distance_cm<13.00){
lcd.clear();
lcd.print("4 kilogram");}
if(11.00<=distance_cm<12.00){
lcd.clear();
lcd.print("4.5 kilogram");}
if(10.00<=distance_cm<11.00){
lcd.clear();
lcd.print("5 kilogram");}
if(9.00<=distance_cm<10.00){
lcd.clear();
lcd.print("5.5 kilogram");}
if(8.00<=distance_cm<9.00){
lcd.clear();
lcd.print("6 kilogram");}
if(7.00<=distance_cm<8.00){
lcd.clear();
lcd.print("6.5 kilogram");}
if(6.00<=distance_cm<7.00){
lcd.clear();
lcd.print("7 kilogram");}
if(5.00<=distance_cm<6.00){
lcd.clear();
lcd.print("7.5 kilogram");}
if(4.00<=distance_cm<5.00){
lcd.clear();
lcd.print("8 kilogram");}
if(3.00<=distance_cm<4.00){
lcd.clear();
lcd.print("8.5 kilogram");
if(2.00<=distance_cm<3.00){
lcd.clear();
lcd.print("9 kilogram");
