Lcd yes or no quiz buttons are not working please help
Were trying to make a yes and no quiz using buttons, if no is pressed it's supposed to move to the next question and if yes is pressed it's supposed to stop any more questions from being asked and make a servo turn, but when we press the buttons, they don't work and the question restarts. Please help!
//using different lcd library from OP
#include <Servo.h>
#include <Wire.h>
#include <hd44780.h>                       // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
hd44780_I2Cexp lcd; // declare lcd object: auto locate & auto config expander chip
Servo servo1; // declaer servo
// LCD geometry
const int LCD_COLS = 21;
const int LCD_ROWS = 20;
const int PIN_RED   = 3;
const int PIN_GREEN = 4;
const int PIN_BLUE  = 5;
//states
enum {ST_q1, ST_q2, ST_q3, ST_q4, ST_q5, ST_haveATreat, ST_noTreatForAYou} currentQuestion = ST_q1;
const int servoPin=6;
bool yes = false;
bool no = false;
const byte yesPin = 8;
bool yesState;
bool lastYesState;
const byte noPin = 9;
bool noState;
bool lastNoState;
  pinMode (servoPin, OUTPUT);
pinMode(PIN_RED,   OUTPUT);
pinMode(PIN_GREEN, OUTPUT);
pinMode(PIN_BLUE,  OUTPUT);
  // initialize serial communication:
  Serial.println("setup() ... ");
  Serial.println("*** facist quiz ***");
  Serial.print("Compiler: ");
  Serial.print(__VERSION__);
  Serial.print(", Arduino IDE: ");
  Serial.println(ARDUINO);
  Serial.print("Created: ");
  Serial.print(__TIME__);
  Serial.print(", ");
  Serial.println(__DATE__);
  Serial.println(__FILE__);
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(yesPin, INPUT_PULLUP);
  pinMode(noPin, INPUT_PULLUP);
  //initialize button states
  yesState = digitalRead(yesPin);
  lastYesState = yesState;
  noState = digitalRead(noPin);
  lastNoState = noState;
  lcd.begin(LCD_COLS, LCD_ROWS);
  lcd.setCursor(0, 0);
  lcd.print("FACIST...");
  lcd.setCursor(0, 1);
  lcd.print("        ...QUIZ");
  Serial.println("setup() done");
  Serial.println(" ");
void loop(){
  yes = checkYesButton();
  no = checkNoButton();
  askQuestions();
} //loop
void askQuestions()
  switch (currentQuestion) //ST_q1, ST_q2, ST_q3, ST_q4, ST_q5, ST_haveASnack, ST_noSoupAForAYou
    case ST_q1:
      q1();
      countdown ();
      if (yes){ //this would only have been returned true by checkYesButton() if the yes button was pressed
        currentQuestion = ST_noTreatForAYou;
        yes = false;
      if (no) //this would only have been returned true by checkNoButton() if the no button was pressed
        currentQuestion = ST_q2;
        no = false;
    case ST_q2:
      q2();
      countdown();
      if (yes) //this would only have been returned true by checkYesButton() if the yes button was pressed
        yes = false;
        currentQuestion = ST_q3;
        no = false;
    case ST_q3:
      q3();
      countdown();
        currentQuestion = ST_q4;
        no = false;
        yes = false;
    case ST_q4:
      q4();
      countdown();
        no = false;
        currentQuestion = ST_q5;
        yes = false;
    case ST_q5:
      q5();
      countdown();
        currentQuestion = ST_haveATreat;
        no = false;
        yes = false;
    case ST_haveATreat:
    yay();
      lcd.print("CONGRATULATIONS!");
      lcd.print("HAVE A LITTLE TREAT! ");
    case ST_noTreatForAYou:
    facist();
      lcd.print("NO TREAT...     ");
      lcd.print("  ...FORA YOU FACIST!");
            analogWrite (servoPin, 180);
      delay(3000);
            analogWrite (servoPin, 0);
      delay(3000);
  }//switch
}//askQuestions
void q1 (){
   lcd.clear();                 // clear display
  lcd.setCursor(0, 0);         // move cursor to   (0, 0)
  lcd.print("DO YOU DISPOSE");        // print message at (0, 0)
  lcd.setCursor(9, 1);         // move cursor to   (2, 1)
  lcd.print("OF YOUR"); // print message at (2, 1)
  delay(2000);                 // display the above for two seconds
  lcd.setCursor(3, 0);          // move cursor to   (3, 0)
  lcd.print("POLITICAL");        // print message at (3, 0)
  lcd.setCursor(3, 1);          // move cursor to   (0, 1)
  lcd.print("OPONENTS?"); // print message at (0, 1)
  delay(2000);
void q2 (){
  lcd.print("DO YOU USE FALSE");        // print message at (0, 0)
  lcd.setCursor(1, 1);         // move cursor to   (2, 1)
  lcd.print("STATEMENTS TO"); // print message at (2, 1)
  lcd.setCursor(4, 0);          // move cursor to   (3, 0)
  lcd.print("GET YOUR");        // print message at (3, 0)
  lcd.setCursor(6, 1);          // move cursor to   (0, 1)
  lcd.print("WAY?"); // print message at (0, 1)
  delay(2000);
void q3 (){
  lcd.setCursor(1, 0);         // move cursor to   (0, 0)
  lcd.print("DO YOU PORTRAY");        // print message at (0, 0)
  lcd.print("YOURSELF AS A"); // print message at (2, 1)
  lcd.setCursor(0, 0);          // move cursor to   (3, 0)
  lcd.print("PERFECT HUMAN OR");        // print message at (3, 0)
  lcd.setCursor(0, 1);          // move cursor to   (0, 1)
  lcd.print("SORT OF DEMIGOD?"); // print message at (0, 1)
  delay(2000);
void q4 (){
  lcd.print("DO YOU ALLOW");        // print message at (0, 0)
  lcd.setCursor(0, 1);         // move cursor to   (2, 1)
  lcd.print("PEOPLE TO SPREAD"); // print message at (2, 1)
  lcd.print("THEIR BELIEFS");        // print message at (3, 0)
  lcd.setCursor(8, 1);          // move cursor to   (0, 1)
  lcd.print("THAT ARE"); // print message at (0, 1)
  delay(2000);
  lcd.print("DIFFERENT THAN");        // print message at (3, 0)
  lcd.setCursor(10, 1);          // move cursor to   (0, 1)
  lcd.print("YOURS?"); // print message at (0, 1)
  delay(2000);
void q5 (){
  lcd.setCursor(5, 0);         // move cursor to   (0, 0)
  lcd.print("DO YOU");        // print message at (0, 0)
  lcd.print("CONSTANTLY BLAME"); // print message at (2, 1)
  lcd.print("OTHER");        // print message at (3, 0)
  lcd.print("GROUPS/PEOPLE"); // print message at (0, 1)
  delay(2000);
  lcd.print("FOR  DOWNFALLS");        // print message at (3, 0)
  lcd.setCursor(1, 1);          // move cursor to   (0, 1)
  lcd.print("AND MISFORTUNES"); // print message at (0, 1)
  delay(2000);
  lcd.print("EVEN IF IT HAS");        // print message at (3, 0)
  lcd.print("NOTHING TO DO"); // print message at (0, 1)
  delay(2000);
  lcd.setCursor(5, 0);          // move cursor to   (3, 0)
  lcd.print("WITH");        // print message at (3, 0)
  lcd.print("THEM?"); // print message at (0, 1)
  delay(2000);
void countdown (){
  lcd.print("YOU HAVE");        // print message at (3, 0)
  lcd.print("20 SECONDS"); // print message at (0, 1)
  delay(2000);
  lcd.print("YES OR NO");        // print message at (3, 0)
  lcd.setCursor(7, 1);          // move cursor to   (0, 1)
  lcd.print("20"); // print message at (0, 1)
  delay(1000);                  // display the above for two seconds
  lcd.print("19"); // print message at (0, 1)
  lcd.print("18"); // print message at (0, 1)
  lcd.print("17"); // print message at (0, 1)
  lcd.print("16"); // print message at (0, 1)
  lcd.print("15"); // print message at (0, 1)
  lcd.print("14"); // print message at (0, 1)
  lcd.print("13"); // print message at (0, 1)
  lcd.print("12"); // print message at (0, 1)
  lcd.print("11"); // print message at (0, 1)
  lcd.print("10"); // print message at (0, 1)
  lcd.print("9"); // print message at (0, 1)
  lcd.print("8"); // print message at (0, 1)
  lcd.print("7"); // print message at (0, 1)
  lcd.print("6"); // print message at (0, 1)
  lcd.print("5"); // print message at (0, 1)
  lcd.print("4"); // print message at (0, 1)
  lcd.print("3"); // print message at (0, 1)
  lcd.print("2"); // print message at (0, 1)
  lcd.print("1"); // print message at (0, 1)
  lcd.print("0"); // print message at (0, 1)
  lcd.print("TIME");        // print message at (3, 0)
  lcd.print("IS UP"); // print message at (0, 1)
void facist(){
  for (int i = 0; i < 5; i++) {
      analogWrite(PIN_RED,   250);
  analogWrite(PIN_GREEN, 0);
  analogWrite(PIN_BLUE,  0);
  delay (10);
        analogWrite(PIN_RED,   245);
  delay (10);
        analogWrite(PIN_RED,   240);
  delay (10);
        analogWrite(PIN_RED,   235);
  delay (10);
        analogWrite(PIN_RED,   230);
  delay (10);
        analogWrite(PIN_RED,   225);
  delay (10);
        analogWrite(PIN_RED,   220);
  delay (10);
        analogWrite(PIN_RED,   215);
  delay (10);
        analogWrite(PIN_RED,   210);
  delay (10);
        analogWrite(PIN_RED,   205);
  delay (10);
        analogWrite(PIN_RED,   200);
  delay (10);
        analogWrite(PIN_RED,   195);
  delay (10);
        analogWrite(PIN_RED,   190);
  delay (10);
        analogWrite(PIN_RED,   185);
  delay (10);
        analogWrite(PIN_RED,   180);
  delay (10);
        analogWrite(PIN_RED,   175);
  delay (10);
        analogWrite(PIN_RED,   170);
  delay (10);
        analogWrite(PIN_RED,   165);
  delay (10);
        analogWrite(PIN_RED,   160);
  delay (10);
        analogWrite(PIN_RED,   155);
  delay (10);
        analogWrite(PIN_RED,   150);
  delay (10);
        analogWrite(PIN_RED,   145);
  delay (10);
        analogWrite(PIN_RED,   140);
  delay (10);
        analogWrite(PIN_RED,   135);
  delay (10);
        analogWrite(PIN_RED,   130);
  delay (10);
        analogWrite(PIN_RED,   125);
  delay (10);
        analogWrite(PIN_RED,   120);
  delay (10);
        analogWrite(PIN_RED,   115);
  delay (10);
        analogWrite(PIN_RED,   110);
  delay (10);
        analogWrite(PIN_RED,   105);
  delay (10);
        analogWrite(PIN_RED,   100);
  delay (10);
        analogWrite(PIN_RED,   95);
  delay (10);
        analogWrite(PIN_RED,   90);
  delay (10);
        analogWrite(PIN_RED,   85);
  delay (10);
        analogWrite(PIN_RED,   80);
  delay (10);
        analogWrite(PIN_RED,   75);
  delay (10);
        analogWrite(PIN_RED,   70);
  delay (10);
        analogWrite(PIN_RED,   65);
  delay (10);
        analogWrite(PIN_RED,   60);
  delay (10);
        analogWrite(PIN_RED,   55);
  delay (10);
        analogWrite(PIN_RED,   50);
  delay (10);
        analogWrite(PIN_RED,   45);
  delay (10);
        analogWrite(PIN_RED,   40);
  delay (10);
        analogWrite(PIN_RED,   35);
  delay (10);
        analogWrite(PIN_RED,   30);
  delay (10);
        analogWrite(PIN_RED,   25);
  delay (10);
        analogWrite(PIN_RED,   20);
  delay (10);
        analogWrite(PIN_RED,   15);
  delay (10);
        analogWrite(PIN_RED,   10);
  delay (10);
        analogWrite(PIN_RED,   5);
  delay (10);
        analogWrite(PIN_RED,   0);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
void red(){
    analogWrite(PIN_RED,   255);
  delay (10);
void yellow(){
  analogWrite(PIN_GREEN, 255);
  delay (10);
void green(){
  delay (10);
void cyan(){
  analogWrite(PIN_BLUE,  255);
  delay (10);
void blue() {
  delay (10);
void pink(){
  delay (10);
void yay() {
red ();
  analogWrite(PIN_GREEN, 5);
  delay (10);
  analogWrite(PIN_GREEN, 10);
  delay (10);
  analogWrite(PIN_GREEN, 15);
  delay (10);
  analogWrite(PIN_GREEN, 20);
  delay (10);
  analogWrite(PIN_GREEN, 25);
  delay (10);
  analogWrite(PIN_GREEN, 30);
  delay (10);
  analogWrite(PIN_GREEN, 40);
  delay (10);
  analogWrite(PIN_GREEN, 45);
  delay (10);
  analogWrite(PIN_GREEN, 50);
  delay (10);
  analogWrite(PIN_GREEN, 55);
  delay (10);
  analogWrite(PIN_GREEN, 60);
  delay (10);
  analogWrite(PIN_GREEN, 65);
  delay (10);
  analogWrite(PIN_GREEN, 70);
  delay (10);
  analogWrite(PIN_GREEN, 75);
  delay (10);
  analogWrite(PIN_GREEN, 80);
  delay (10);
  analogWrite(PIN_GREEN, 85);
  delay (10);
  analogWrite(PIN_GREEN, 90);
  delay (10);
  analogWrite(PIN_GREEN, 95);
  delay (10);
  analogWrite(PIN_GREEN, 100);
  delay (10);
  analogWrite(PIN_GREEN, 105);
  delay (10);
  analogWrite(PIN_GREEN, 110);
  delay (10);
  analogWrite(PIN_GREEN, 115);
  delay (10);
  analogWrite(PIN_GREEN, 120);
  delay (10);
  analogWrite(PIN_GREEN, 125);
  delay (10);
  analogWrite(PIN_GREEN, 130);
  delay (10);
  analogWrite(PIN_GREEN, 135);
  delay (10);
  analogWrite(PIN_GREEN, 140);
  delay (10);
  analogWrite(PIN_GREEN, 145);
  delay (10);
  analogWrite(PIN_GREEN, 150);
  delay (10);
  analogWrite(PIN_GREEN, 155);
  delay (10);
  analogWrite(PIN_GREEN, 160);
  delay (10);
  analogWrite(PIN_GREEN, 165);
  delay (10);
  analogWrite(PIN_GREEN, 170);
  delay (10);
  analogWrite(PIN_GREEN, 175);
  delay (10);
  analogWrite(PIN_GREEN, 180);
  delay (10);
  analogWrite(PIN_GREEN, 185);
  delay (10);
  analogWrite(PIN_GREEN, 190);
  delay (10);
  analogWrite(PIN_GREEN, 195);
  delay (10);
  analogWrite(PIN_GREEN, 200);
  delay (10);
  analogWrite(PIN_GREEN, 205);
  delay (10);
  analogWrite(PIN_GREEN, 210);
  delay (10);
  analogWrite(PIN_GREEN, 215);
  delay (10);
  analogWrite(PIN_GREEN, 220);
  delay (10);
  analogWrite(PIN_GREEN, 225);
  delay (10);
  analogWrite(PIN_GREEN, 230);
  delay (10);
  analogWrite(PIN_GREEN, 235);
  delay (10);
  analogWrite(PIN_GREEN, 240);
  delay (10);
  analogWrite(PIN_GREEN, 245);
  delay (10);
  analogWrite(PIN_GREEN, 250);
  delay (10);
yellow ();
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  green();
  analogWrite(PIN_BLUE,  5);
  delay (10);
  analogWrite(PIN_BLUE,  10);
  delay (10);
  analogWrite(PIN_BLUE,  15);
  delay (10);
  analogWrite(PIN_BLUE,  20);
  delay (10);
  analogWrite(PIN_BLUE,  25);
  delay (10);
  analogWrite(PIN_BLUE,  30);
  delay (10);
  analogWrite(PIN_BLUE,  35);
  delay (10);
  analogWrite(PIN_BLUE,  40);
  delay (10);
  analogWrite(PIN_BLUE,  45);
  delay (10);
  analogWrite(PIN_BLUE,  50);
  delay (10);
  analogWrite(PIN_BLUE,  55);
  delay (10);
  analogWrite(PIN_BLUE,  60);
  delay (10);
  analogWrite(PIN_BLUE,  65);
  delay (10);
  analogWrite(PIN_BLUE,  70);
  delay (10);
  analogWrite(PIN_BLUE,  75);
  delay (10);
  analogWrite(PIN_BLUE,  80);
  delay (10);
  analogWrite(PIN_BLUE,  85);
  delay (10);
  analogWrite(PIN_BLUE,  90);
  delay (10);
  analogWrite(PIN_BLUE,  95);
  delay (10);
  analogWrite(PIN_BLUE,  100);
  delay (10);
  analogWrite(PIN_BLUE,  105);
  delay (10);
  analogWrite(PIN_BLUE,  110);
  delay (10);
  analogWrite(PIN_BLUE,  115);
  delay (10);
  analogWrite(PIN_BLUE,  120);
  delay (10);
  analogWrite(PIN_BLUE,  125);
  delay (10);
  analogWrite(PIN_BLUE,  130);
  delay (10);
  analogWrite(PIN_BLUE,  135);
  delay (10);
  analogWrite(PIN_BLUE,  140);
  delay (10);
  analogWrite(PIN_BLUE,  145);
  delay (10);
  analogWrite(PIN_BLUE,  150);
  delay (10);
  analogWrite(PIN_BLUE,  155);
  delay (10);
  analogWrite(PIN_BLUE,  160);
  delay (10);
  analogWrite(PIN_BLUE,  165);
  delay (10);
  analogWrite(PIN_BLUE,  170);
  delay (10);
  analogWrite(PIN_BLUE,  175);
  delay (10);
  analogWrite(PIN_BLUE,  180);
  delay (10);
  analogWrite(PIN_BLUE,  185);
  delay (10);
  analogWrite(PIN_BLUE,  190);
  delay (10);
  analogWrite(PIN_BLUE,  195);
  delay (10);
  analogWrite(PIN_BLUE,  200);
  delay (10);
  analogWrite(PIN_BLUE,  205);
  delay (10);
  analogWrite(PIN_BLUE,  210);
  delay (10);
  analogWrite(PIN_BLUE,  215);
  delay (10);
  analogWrite(PIN_BLUE,  220);
  delay (10);
  analogWrite(PIN_BLUE,  225);
  delay (10);
  analogWrite(PIN_BLUE,  230);
  delay (10);
  analogWrite(PIN_BLUE,  235);
  delay (10);
  analogWrite(PIN_BLUE,  240);
  delay (10);
  analogWrite(PIN_BLUE,  245);
  delay (10);
  analogWrite(PIN_BLUE,  250);
  delay (10);
cyan ();
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  analogWrite(PIN_GREEN, 35);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  blue();
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
pink ();
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
  delay (10);
bool checkYesButton()
  bool temp = false;
  // read the button:
  if (yesState == LOW && lastYesState == HIGH)
    Serial.println("New yes ");
    temp = true;
    // Delay a little bit to avoid bouncing
    delay(50);
  }//change
  return temp;
}//yes
bool checkNoButton()
  bool temp = false;
  // read the button:
  // compare the buttonState to its previous state
  if (noState == LOW && lastNoState == HIGH)
    Serial.println("New no ");
    temp = true;
    delay(50);
  }//change
  // save the current state as the last state, for next time through the loop
  return temp;
}//no
this is the circuitry
Is this correct?
yes,
because the buttons think they are always being pushed so i don't know what is wrong with it.
I want to help but I do not understand what you have. You took nice pictures but they do not tell me anything. For me a Schematic is needed, not a frizzy picture or photographs.
