LCD03 I2C
Sto provando qualche pezzo di codice per capire come usare uesto LCD.
Provando la libreria LCDi2cR però non me lo compila e si ferma su questa riga:
LCDi2cR lcd = LCDi2cR(4,40,0x63,0);
con questo errore:
LCDi2cR does not name a type
Questo è il codice:
// []       i2c LCD library Custom Character
// []	4-2-2009  dale@wentztech.com
#define VERSION "1.2"
#include <Wire.h>
#include "macros.h"
//  Uncomment the two lines for the display you are using
//	web4robot.com display
//#include <LCDi2cW.h>
//LCDi2cW lcd = LCDi2cW(2,16,0x4C,0);
 //   robot-electronics.co.uk
#include <LCDi2cR.h>
  //    Note custom char 0 does not work on version 1.3 or 1.4 of the web4robots display
  //    Define Custom Characters 0 - 7
  //    A 1 in the binary representation of the character means it is filled in
  //    characters are 5 pixels wide by 7 pixels tall
  uint8_t cc0[8] = {     // Custom Character 0
    B8(00000),
    B8(10001),
    B8(01010),
    B8(00100),
    B8(01010),
    B8(10001),
    B8(00000),
    B8(00000)
  uint8_t cc1[8] = {     // Custom Character 1
    B8(10001),
    B8(01110),
    B8(10101),
    B8(01110),
    B8(10001),
    B8(10001),
    B8(00000),
    B8(00000)
  uint8_t cc2[8] = {    // Custom Character 2
    B8(10001),
    B8(01110),
    B8(10101),
    B8(01110),
    B8(01010),
    B8(01010),
    B8(00000),
    B8(00000)
  uint8_t cc3[8] = {   // Custom Character 3
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000)
 uint8_t cc4[8] = {    // Custom Character 4
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00100),
    B8(01110),
    B8(11111)
 uint8_t cc5[8] = {   // Custom Character 5
    B8(00100),
    B8(00100),
    B8(00100),
    B8(00100),
    B8(00000),
    B8(00100),
    B8(01110),
    B8(11111)
  uint8_t cc6[8] = {  // Custom Character 6
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00100),
    B8(00100),
    B8(00100),
    B8(00100)
  uint8_t cc7[8] = {   // Custom Character 7
    B8(00100),
    B8(00100),
    B8(00100),
    B8(00100),
    B8(00000),
    B8(00000),
    B8(00000),
    B8(00000)
  lcd.init();                             // Init the display
  lcd.load_custom_character(0,cc0);      // send custom characters to the display
  lcd.load_custom_character(1,cc1);
  lcd.load_custom_character(2,cc2);
  lcd.load_custom_character(3,cc3);
  lcd.load_custom_character(4,cc4);
  lcd.load_custom_character(5,cc5);
  lcd.load_custom_character(6,cc6);
  lcd.load_custom_character(7,cc7);
  lcd.clear();                          // clear the display after sending characters. Cursor goes to odd place after uploading
  lcd.print("Hello World!");            // Print hello world and customer characters
  lcd.setCursor(1,0);                   // Print out the custom characters from 0 to 7 on next line
  for(int i=0; i<8 ; i++){
      lcd.write(i);
  delay(2000);                          // just sleep a bit so we can see the display
  lcd.clear();
void loop()            // Space invaders loop
  int j=1;
  int move=1;
  int pos=1;
  int posmove=1;
  for(int i=0;i < 2000;i++){
      lcd.setCursor(0,pos);
      lcd.print(" ");
      lcd.write(0x01);
      lcd.print(" ");
      lcd.setCursor(0,pos+4);
      lcd.print(" ");
      lcd.write(0x02);
      lcd.print(" ");
      if (j == 15)
        move = -1;
      if (j == 0)
        move = 1;
      lcd.setCursor(1,j);
      lcd.print(" ");
      lcd.write(0x04);
      lcd.print(" ");
      j = j + move;
      #ifdef LCDi2cR_h
      delay(200);     // If using with the robot electronics display we need to add a delay, as the display is to fast
      #endif
      lcd.print(" ");
      lcd.write(0x02);
      lcd.print(" ");
      lcd.print(" ");
      lcd.write(0x01);
      lcd.print(" ");
      if(pos == 0)
        posmove = 1;
      if(pos == 10)
        posmove = -1;
      pos = pos + posmove;
      #ifdef LCDi2cR_h
      #endif
Perchè ?
Grazie, Alberto
Scusate .... avevo la libreria in un'altra directory $)
