LCD12864SPI
Je vois que c'est compliqué. !!!
J'ai un peu ..... tout petit peu avancé et j'ai une librairie qui m'a l'air correcte.
class LCD12864RSPI {
	typedef unsigned char uchar;
public:
	LCD12864RSPI();
	void initialise(void);         /* Initialize the screen. */
	void delayns(void);            /* Delay dalayTime amount of microseconds. */
	void writeByte(int data);      /* Write byte data. */
	void writeCommand(int cmd);    /* Write command cmd into the screen. */
	void writeData(int data);      /* Write data data into the screen. */
	void moveCursor(int X, int Y); /* Move cursor to 0-based column X and 0-based row Y as the starting point of the next display. */
	void clear(void);			                    /* Clear the screen. */
	void clearRow(int Y);                           /* Clear the y-th row (y is 0-based) */
	void fillBlock(int X, int Y, uchar c, int len); /* Fill block starting from 0-based column X and 0-based row Y with the character c. The filled block is of length len.*/
	void clearBlock(int X, int Y, int length);      /* Clear the block starting from 0-based column X and 0-based row Y. The cleared block is of len byte long. */
	void printf(int X, int Y, char *fmt, ... );         /* Display formated string at 0-based column X and 0-based row Y. The formatted string should not be longer than 64 characters. */
	void displayString(int X,int Y,uchar *ptr,int dat); /* Display string ptr (with length len) at 0-based column X and 0-based row Y. */
	void displaySig(int M,int N,int sig);               /* Display a single character sig at 0-based column X and 0-based row Y. */
	void displayInteger(int X, int Y, int number);      /* Display integer number at 0-based column X and 0-based row Y. */
	void drawFullScreen(uchar *p);  /* Display the full screen using data from p. */
	void drawImage1(uchar img[]);   /* Display image */
	void drawImage2(uchar img[]);   /* Display image */
	int delayTime;    /* Delay time in microseconds. */
	int DEFAULTTIME;  /* Default delay time. */
	static const int latchPin = 8;
	static const int clockPin = 3;
	static const int dataPin  = 9;
Avec cela je dois pouvoir afficher un gros chiffre avec "displayImage" ou "displayString"
Merci pour l'aide.
