how i can connect it and what a library and code i need to use
am usin this sample codes that are succesfuly compliled and transferred to device but no reaction - only light
http://www.elecfreaks.com/wiki/index.php?title=2.4"_TFT_LCD:_TFT01-2.4
I thinking i using not true pins... But i cant do it work. help please
help please, really need help
skype, or other ?
Hi, please consider my LCD if you need better results. i recently launch LCDBPV2 libraries for arduino. LCDBPV2 is a 3.2" 320x240 and 16 bits color more cheap than similar solution but better because awesome speed.
Please check youtube video: http://youtu.be/69TIaPOkcns
here are more information: http://danirebollo.es/index.php/blog/item/23-lcd-boosterpack-v2
Greetings.
hello, tnx, but i want to work with this lsd and this shield
tft lcd 16 bits 4 bit touch panel and elec freaks shield V.2.0
lcd have a 240x400 resolution and sd csard slot
this display and fucked shield V2.0
I have this shield and a TFT_320QVT
Download the UTFT and UTFT_geometry libraries
You need to define your TFT chipset and pin connections.
The default
UTFT myGLCD(ITDB32S,38,39,40,41);
works fine right out of the box.
Be careful when unpacking the RAR files. Your folder tree should be
\Program Files\Arduino\libraries\UTFT
\Program Files\Arduino\libraries\UTFT_geometry
If you unpack UTFT.rar into UTFT you'll get
\Program Files\Arduino\libraries\UTFT\UTFT which wont work.
