LCD4Bit_mod int to char help
I am tryin to display Data from my EDB to my LCD Input Shield.
Whenever i try to print out data i get funny characters.
So I tried just displaying the Value of a button press!! Instead of displaying 304,719,476,129,0 i’m just getting junk!
#include <LCD4Bit_mod.h>
//create object to control an LCD.
//number of lines in display=1
LCD4Bit_mod lcd = LCD4Bit_mod(2);
lcd.init();
//optionally, now set up our application-specific display settings, overriding whatever the lcd did in lcd.init()
lcd.commandWrite(0x0F);//cursor on, display on, blink on. (nasty!)
lcd.clear();
lcd.clear();
int msg;
lcd.cursorTo(1, 0);
lcd.printIn(“Brain Sytem”);
msg = analogRead(0);
char myChar = msg;
Serial.println(msg);
lcd.cursorTo(2, 0);
lcd.print(myChar);
can anyone help?
Thanks in advance
As I recall, lcd4bit does not print integer values which is I think what you want. I suggest you use the LiquieCrystal library which has the same print capability as serial.
Here is some code for LiquidCrystal that should be close to what you want:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  lcd.begin(2, 16);
  lcd.blink(); // if you really want this mode!
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Brain Sytem");
  int msg = analogRead(0);
  lcd.setCursor(1, 0);
  lcd.print(msg);
see the LiquidCrystal reference for more on its capabilities
cheers,
got it working with my dfrobot shield.
how can i use the button with a menu system.
basically scrolling through the records on the EEPROM?
got any ideas?
thanks in advance
You should be able to gather some ideas doing a search for arduino lcd menu discussions in the forum and in the playground.
have fun!
