lcdhello
Attached are the libraries im using (multilcd specfically).
This sketch is in the mulilcd library, called "lcdhelo". It does not compile when I use the last lcd option (LCD_ILI9325D)
* Demo sketch of Arduino Text Display Library for Multiple LCDs
* Distributed under GPL v2.0
* Copyright (c) 2013 Stanley Huang <stanleyhuangyc@live.com>
* All rights reserved.
#include <Arduino.h>
#include <Wire.h>
#include <MultiLCD.h>
//LCD_SSD1306 lcd; /* for SSD1306 OLED module */
//LCD_PCD8544 lcd; /* for LCD4884 shield or Nokia 5100 screen module */
//LCD_1602 lcd; /* for LCD1602 shield */
//LCD_ZTOLED lcd; /* for ZT OLED module */
LCD_ILI9325D lcd; /* for Itead 2.8" TFT shield */
static const PROGMEM uint8_t smile[48 * 48 / 8] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xF8,0xFC,0xFC,0xFE,0xFE,0x7E,0x7F,0x7F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x7F,0x7F,0x7E,0xFE,0xFE,0xFC,0xFC,0xF8,0xF8,0xF0,0xE0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xC0,0xF0,0xFC,0xFE,0xFF,0xFF,0xFF,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x01,0x03,0x07,0x0F,0x1F,0x3F,0xFF,0xFF,0xFF,0xFE,0xFC,0xF0,0xC0,0x00,
0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x1F,0x1F,0x1F,0x3F,0x1F,0x1F,0x02,0x00,0x00,0x00,0x00,0x06,0x1F,0x1F,0x1F,0x3F,0x1F,0x1F,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x00,0x30,0xF8,0xF8,0xF8,0xF8,0xE0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF8,0xF8,0xFC,0xF8,0x30,0x00,0x00,0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,
0x00,0x03,0x0F,0x3F,0x7F,0xFF,0xFF,0xFF,0xFC,0xF8,0xF0,0xE1,0xC7,0x87,0x0F,0x1F,0x3F,0x3F,0x3E,0x7E,0x7C,0x7C,0x7C,0x78,0x78,0x7C,0x7C,0x7C,0x7E,0x3E,0x3F,0x3F,0x1F,0x0F,0x87,0xC7,0xE1,0xF0,0xF8,0xFC,0xFF,0xFF,0xFF,0x7F,0x3F,0x0F,0x03,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x07,0x0F,0x1F,0x1F,0x3F,0x3F,0x7F,0x7F,0x7E,0xFE,0xFE,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFE,0xFE,0x7E,0x7F,0x7F,0x3F,0x3F,0x1F,0x1F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
	lcd.begin();
	lcd.clear();
	lcd.draw(smile, 40, 8, 48, 48);
	lcd.clear();
	lcd.setCursor(0, 0);
	lcd.setFont(FONT_SIZE_SMALL);
	lcd.print("Hello, world!");
	lcd.setCursor(0, 1);
	lcd.setFont(FONT_SIZE_MEDIUM);
	lcd.setCursor(0, 3);
	lcd.printLong(12345678);
	lcd.setCursor(64, 3);
	lcd.setCursor(0, 4);
	lcd.setFont(FONT_SIZE_LARGE);
	lcd.setCursor(0, 6);
	lcd.setFont(FONT_SIZE_XLARGE);
	delay(3000);
It does not compile when I use the LCD for the 2.8" TFT...the others do compile however. Am I the only one getting an error when compiling with the last LCD option? (LCD_ILI9325D)
megalogger-src-20130801.zip (106 KB)
Compile only if you select "Arduino Mega" on IDE board.
In the file ILI9325D.cpp I see:
#if defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1280__)
that class for ILI is compiled only if you select mega.
Oh, that makes sense!
Thank you! :smiley:
