I was looking for this and had hard time finding it so here it is...
uses new lcd crystal library form 16+ IDE
the example was from nuelectronics or something and I modified it little bit.
Use matrix.dll in lcd smartie setup.
setup your comport and 9600 baudrate.
The circuit:
- LCD RS pin to digital pin 5
- LCD R/W pin to digital pin 6
- LCD Enable pin to digital pin 7
- LCD D4 pin to digital pin 8
- LCD D5 pin to digital pin 9
- LCD D6 pin to digital pin 10
- LCD D7 pin to digital pin 11
- 10K resistor:
- ends to +5V and ground
- wiper to LCD VO pin (pin 3)
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(5, 6, 7, 8, 9, 10, 11);
// set up the LCD's number of columns and rows:
lcd.begin(2, 16);
byte serial_getch(){
int incoming;
while (Serial.available()==0){}
// read the incoming byte:
incoming = Serial.read();
return (byte) (incoming &0xff);
void loop(){
byte rxbyte;
byte temp;
rxbyte = serial_getch();
if (rxbyte == 254) //Matrix Orbital uses 254 prefix for commands
switch (serial_getch())
case 66: //backlight on (at previously set brightness)
// not implemented
case 70: //backlight off
// not implemented
case 71: //set cursor position
temp = (serial_getch() - 1); //get column byte
switch (serial_getch()) //get row byte
//line 1 is already set up
case 2:
temp += 0x40;
case 3:
temp += 0x14;
case 4:
temp += 0x54;
default:
lcd.command(0b10000000 + temp);
case 72: //cursor home (reset display position)
lcd.command(2);
case 74: //show underline cursor
lcd.command(0b00001110);
case 75: //underline cursor off
case 84: //block cursor off
lcd.command(0b00001100);
case 76: //move cursor left
lcd.command(16);
case 77: //move cursor right
lcd.command(20);
case 78: //define custom char
lcd.command(64 + (serial_getch() * 8)); //get+set char address
for (temp = 7; temp != 0; temp--)
lcd.print(serial_getch()); //get each pattern byte
case 83: //show blinking block cursor
lcd.command(0b00001111);
case 86: //GPO OFF
//implement later
case 87: //GPO ON
/temp = serial_getch();
if (temp == 1)
GPO1 = GPO_ON;
case 88: //clear display, cursor home
lcd.command(1);
case 152: //set and remember (doesn't save value, though)
case 153: //set backlight brightness
//not implemented
//these commands ignored (no parameters)
case 35: //read serial number
case 36: //read version number
case 55: //read module type
case 59: //exit flow-control mode
case 65: //auto transmit keypresses
case 96: //auto-repeat mode off (keypad)
case 67: //auto line-wrap on
case 68: //auto line-wrap off
case 81: //auto scroll on
case 82: //auto scroll off
case 104: //init horiz bar graph
case 109: //init med size digits
case 115: //init narrow vert bar graph
case 118: //init wide vert bar graph
default:
//all other commands ignored and parameter byte discarded
temp = serial_getch(); //dump the command code
return;
} //END OF COMMAND HANDLER
//change accented char to plain, detect and change descenders
//NB descenders only work on 5x10 displays. This lookup table works
// with my DEM-20845 (Display Elektronik GmbH) LCD using KS0066 chip.
switch (rxbyte)
//chars that have direct equivalent in LCD charmap
/* case 0x67: //g
rxbyte = 0xE7;
case 0x6A: //j
rxbyte = 0xEA;
case 0x70: //p
rxbyte = 0xF0;
case 0x71: //q
rxbyte = 0xF1;
case 0x79: //y
rxbyte = 0xF9;
*/ case 0xE4: //ASCII "a" umlaut
rxbyte = 0xE1;
case 0xF1: //ASCII "n" tilde
rxbyte = 0xEE;
case 0xF6: //ASCII "o" umlaut
rxbyte = 0xEF; //was wrong in v0.86
case 0xFC: //ASCII "u" umlaut
rxbyte = 0xF5;
//accented -> plain equivalent
//and misc symbol translation
case 0xA3: //sterling (pounds)
rxbyte = 0xED;
/* case 0xB0: //degrees symbol
rxbyte = 0xDF;
/ case 0xB5: //mu
rxbyte = 0xE4;
case 0xC0: //"A" variants
case 0xC1:
case 0xC2:
case 0xC3:
case 0xC4:
case 0xC5:
rxbyte = 0x41;
case 0xC8: //"E" variants
case 0xC9:
case 0xCA:
case 0xCB:
rxbyte = 0x45;
case 0xCC: //"I" variants
case 0xCD:
case 0xCE:
case 0xCF:
rxbyte = 0x49;
case 0xD1: //"N" tilde -> plain "N"
rxbyte = 0x43;
case 0xD2: //"O" variants
case 0xD3:
case 0xD4:
case 0xD5:
case 0xD6:
case 0xD8:
rxbyte = 0x4F;
case 0xD9: //"U" variants
case 0xDA:
case 0xDB:
case 0xDC:
rxbyte = 0x55;
case 0xDD: //"Y" acute -> "Y"
rxbyte = 0x59;
/ case 0xDF: //beta //mucks up LCDSmartie's degree symbol??
rxbyte = 0xE2;
*/ case 0xE0: //"a" variants except umlaut
case 0xE1:
case 0xE2:
case 0xE3:
case 0xE5:
rxbyte = 0x61;
case 0xE7: //"c" cedilla -> "c"
rxbyte = 0x63;
case 0xE8: //"e" variants
case 0xE9:
case 0xEA:
case 0xEB:
rxbyte = 0x65;
case 0xEC: //"i" variants
case 0xED:
case 0xEE:
case 0xEF:
rxbyte = 0x69;
case 0xF2: //"o" variants except umlaut
case 0xF3:
case 0xF4:
case 0xF5:
case 0xF8:
rxbyte = 0x6F;
case 0xF7: //division symbol
rxbyte = 0xFD;
case 0xF9: //"u" variants except umlaut
case 0xFA:
case 0xFB:
rxbyte = 0x75;
default:
lcd.print(rxbyte); //otherwise a plain char so we print it to lcd
return;
