ld returned 1 exit status - for minimal sketch
Dear pros,
I tried to compile the absolute minimum of a sketch and upload it to an Uno:
I get following error:
Arduino: 1.8.6 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\vid\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10806 -build-path C:\Users\vid\AppData\Local\Temp\arduino_build_178663 -warnings=none -build-cache C:\Users\vid\AppData\Local\Temp\arduino_cache_312230 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\vid\AppData\Local\Temp\untitled812700306.tmp\sketch_sep10a\sketch_sep10a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\vid\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10806 -build-path C:\Users\vid\AppData\Local\Temp\arduino_build_178663 -warnings=none -build-cache C:\Users\vid\AppData\Local\Temp\arduino_cache_312230 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\vid\AppData\Local\Temp\untitled812700306.tmp\sketch_sep10a\sketch_sep10a.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663\\sketch\\sketch_sep10a.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663\\sketch\\sketch_sep10a.ino.cpp" -o "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10806 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663\\sketch\\sketch_sep10a.ino.cpp" -o "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663\\sketch\\sketch_sep10a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\wiring_analog.c.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\WInterrupts.c.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\hooks.c.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\wiring_digital.c.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\wiring_shift.c.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\wiring.c.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\WMath.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\abi.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\WString.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\new.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\CDC.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\Tone.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\Stream.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\USBCore.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\main.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\Print.cpp.o
Using previously compiled file: C:\Users\vid\AppData\Local\Temp\arduino_build_178663\core\core.a
Archiving built core (caching) in: C:\Users\vid\AppData\Local\Temp\arduino_cache_312230\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663/sketch_sep10a.ino.elf" "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663\\sketch\\sketch_sep10a.ino.cpp.o" "C:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663/core\\core.a" "-LC:\\Users\\vid\\AppData\\Local\\Temp\\arduino_build_178663" -lm
`__vector_16' referenced in section `.vectors' of c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/lib/avr5/crtatmega328p.o: defined in discarded section `.text' of wiring.c.o (symbol from plugin)
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
I know that this might be a generic error and might be linked to my operating system. Any help or hint in the right direction would be highly appreciated.
Best regards
Not even so much as a WARNING here on win 7 x64 pro.
Is it a clone or the real thing ?
Are you using USB 2.0 or 3.0 ports ?
Have you tried with any extra security (antivirus and such) turned off ?
Have you tried other USB cables ?
Does the board show up correctly in DEVICE MANAGER ?
Make sure you have nothing else connected to the board and power it just from the USB !
Close IDE, open it and compile.
You're compiling for an Uno, but your output shows HardwareSerial1,2,3 (for mega) as well as stuff that seems to be for 32U4 based board (Leonardo,...), network stuff etc.
This is probably the most meaningful part.
Maybe you're experiencing a mismatched AVR core and toolchain, perhaps related to issue #7973?
Recommend downloading the "hourly build" to get a copy with problem fixed. Or wait for the 1.8.7 release, probably coming later today. When you run the fixed version, click Tools > Boards > Manage Boards and update the AVR boards. Maybe that will solve this problem?
Hi everybody!
thank you very much for the swift response! It is a real machine, I am using a USB 2.0 port. The board is connected to the PC through a hub (using several boards (all Unos) in parallel - has been working fine for weeks until the reported error occurred...). The boards show up correctly in the device manager. The boards are powered through dedicated power supplies, which is needed for the application. Yesterday I have tried different USB cables, reinstalling the IDE and all kinds of different settings in the IDE and deleting the settings file in the Arduino15 folder to start off fresh. Nothing worked so far.
I will go to my lab in a minute and try:
  • switching off the external power supply of my Arduinos
  • try with antivirus switched off
  • try the latest build/1.8.7
Disconnecting everything from the board is difficult. The Unos are built into a box with some more electronics, each Uno carries a stack of 3 adafruit motor driver shields. I would like to avoid opening and disconnecting everything (it used to be fully operational in this configuration!).
Many thanks for the suggestions up to this point. I will report on my progress after lunch :wink:
You don't need to bother with USB cables, disconnecting things from the board, and the power supply. This is a compiler error. It's completely unrelated to hardware. It will happen even if you don't have the board plugged into your computer.
That's true. Same error occurs with nothing connected.
Hi all,
I went through the list of proposed solutions, without success so far. So I am waiting for 1.8.7, or a fresh hourly build.
sterretje:
I also find that quite strange. I think things got messed up after a Windows update. What can I do to really get back to ground zero in terms of the Arduino IDE and try a fresh start?
Regards.
bear05:
There are three separate folders used by the Arduino IDE:
  • Arduino IDE installation folder: C:\Program Files (x86)\Arduino
  • Data folder: C:\Users\vid\AppData\Local\Arduino15
  • Sketchbook folder: C:\Users\vid\Documents\Arduino
Compilation output is also stored in a couple different folders. These have randomized names and should be deleted every time you exit the Arduino IDE (hence sterretje's advice). In the output you provided above they are:
  • C:\Users\vid\AppData\Local\Temp\arduino_build_178663
  • C:\Users\vid\AppData\Local\Temp\arduino_cache_312230
Hi pert - thanks for the guiding.
I deleted the IDE and all associated folders from ..\AppData\Local and ..\AppData\Local\Temp.
Then I downloaded the latest currently available hourly build (IDE says: Sept 10, 06:33, homepage says: Sept 10, 18:13, but anyhow...).
Upon running above minimal sketch I get the same type of error (this time short output):
Arduino: 1.8.7 Hourly Build 2018/09/10 06:33 (Windows 7), Board: "Arduino/Genuino Uno"
`__vector_16' referenced in section `.vectors' of c:/users/vid/downloads/arduino-nightly/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/lib/avr5/crtatmega328p.o: defined in discarded section `.text' of wiring.c.o (symbol from plugin)
c:/users/vid/downloads/arduino-nightly/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
exit status 1
option enabled in File -> Preferences.
Any help is greatly appreciated. The rest of my setup seems to work and I have to use this opportunity :wink:
Hi folks,
I again tried deleting and reinstalling everything - same result.
Then I tried the Arduino web editor, which compiles all my sketches nicely, but seems to have a problem with several Unos being connected at a time - it seems to always default back to one specific COM port.
I really need to get the IDE back working. Or any other solution to flash sketches to my Unos. I have to use my PC, as there is other proprietary software talking to the Unos via serial which can't be installed elsewhere that easily. Please help me, argh. :cry:
Implemented workaround: got the web editor to work for me (the serial monitor doesn't somehow, so using the serial monitor from the IDE).
Sub-optimal solution, but ok for me until I have more time to check more carefully.
Thanks anyhow!
Maybe an overly aggressive anti-virus program with "real time scanning" (or maybe even Windows Defender) is interfering with the compiler's access to files?
Hi pjrc,
we're using Symantec endpoint protection. Same error occurs when I disable it.
Regards
Hi Bear.
IIRC endpoint does not fully disable but keeps a couple of process running.
Better to check that aspect.
Been a while since I used Symantec bloatware.
did anybody found a solution for this issue ?
I'm on Win 7 Pro 64 bit.
I'm spending now 3 days on this issue .... unable to compile anything; even the minimal sketch fails as bear05 mentioned.
Completely cleaned IDE installation (incl. registry cleanup, deleting ..\Arduino15 directory and all AppdData* directories related to Arduino) and re-installed latest IDE version.
The error persists (this is for a minimal sketch with empty Setup() and empty loop() procedures):
exit status 1
Error compiling for board Arduino Nano.
Selecting other boards (e.g. Mega) just change the board mentioned in the error message.
I've seen a lot of entries in different forums to this or similar errors, but have not seen any solution (IDE restart or reboot don't fix it for me).
Does anybody have an idea, how to proceed ?
Thanks
Uef
I see you have a NANO. (according to the error)
What do you really have for the board ?
Did you try both bootloader 328 options in the IDE if it is a NANO ?
@ballscrewbob:
my Nano is a china clone with old bootloader.
I tried both options (old / new bootloader) with no changes.
But same is true for lets say Mega.
I already followed the uninstall and cleaning tips mentioned here: VERY PERSISTNAT undefined reference to `main' ERROR but also didn't help.
I disabled Symantec EP with no effect.
If it really has to do with compiler optimization is there something I can configure on the compiler ?
I'm really desperate how to get back a working Arduino environment like this one I used for years.
Thanks for any help
Uef
In the PREFERENCES for the IDE is a setting for "Aggressively cache compiled core" you could try with that OFF
Below that is a "Check for updates on startup" whilst not related it has fixed some issues for others so also maybe worth a shot.
Unless you actually have a MEGA there is no point selecting it.
Symantec Endpoint has come up as a culprit for IDE issues a few times.
Those cleanup instructions of mine are still valid btw.
IIRC endpoint does not fully disable and there may still be services for EP running.
You should add the Arduino locations to EP's exclusions/whitelist.
In your case it might be worth re-install the IDE with FULL administrative privileges (this is above just a user with admin privileges) Google will give you the details for doing that.
EDIT...
Also found with a search that there are other possible causes. LIST HERE
CLEAN UP BEFORE INSTALLING ANOTHER COPY OF THE IDE OR ARDUINO CREATE.pdf (347 KB)
Hi ballscrewbob,
I already disabled "Aggressively cache compiled core" with no change.
Meanwhile I moved from Win Installer version to zip and tested with 1.8.2 (I used before with no problems) and 1.8.8.
I played around with different version of board managers for Nano/Uno (back 1.6.11) but error remains the same or resulted in a 0 bytes compile.
I also experimented with a beta board manager version 209 which brings the gcc in tool chain to version 7.3.0 (taken from Error Message Will not compile? - Installation & Troubleshooting - Arduino Forum) but nothing changed.
Also tried different combinations of compiler options in platform.txt by removing -flto parameter at different places (hint from another post), but same results as with different board managers.
I disabled Symantec EP (I know there might processes remaining, but co-existed with no problems for years so far) : no change.
I've admin rights on the machine so should not make a difference.
From your search result list I found a hint regarding a damaged COM driver might have been the reason but didn't fit for (checked and reinstalled drivers).
Meanwhile I'm running our of ideas :frowning: (beside using another laptop or online editor (not yet tried))
Uef
P.S.: Merry Christmas to everybody!!
