I'm going to power an Wemos D1 Mini board with one 18650 battery. i allready have HT7333 and MCP1700 LDO regulators that outputs 3.3V to Wemos D1 3.3V pin.
But max current outputs is 250mA. I have heard that the Wemos can peak around 500mA.
I want an regulator that can take 500mA peak.
I can't find regulators in the same package (TO92) and TO220 i think is too big. Som sugestions? Or can i just use HT7333 og MCP1700?
Sorry but in my opinion it will not work. At best you will have about 0.3 volt head room when the battery is charged and a - headroom when it is being used. My recommendation is to use a SEPIC converter or two batteries in series.
The Wemos mini's on board regulator will provide sufficient current for its own use. No external regulator needed, unless you plan to power other devices also.
I have many wemos mini running from 10440 & 18650 size li-ion batteries, 3xAAA NiMH and li-po packs for quite some years with no issues.
That circuit does not sound like it would add significantly to the current consumption. Can you measure the current drawn by the temp sensor and voltage sensor? What current does the Wemos draw when these components are disconnected?
