The NXP has been EoL'd so I need to swap it out with the ST and here is where the problem starts.
If I follow the datasheet and apply a .1uF CAP from VIN (PIN 3) to Ground and a 10uF cap from OUT (PIN 2) to ground as specified in the ST datasheet page 8.
When I place the ST LDO in the circuit and use my multimeter to measure the output I get 2.64 volts from the ST but when I place the NXP in the same circuit I get the correct 1.2V -- can someone explain why I'm seeing this -- I think I'm going crazy!!!!!
I tried both Tant and Ceramic -- even if I pull the LDO and wire it in the "air" I get 2.64v from 3.3v input -- what's even more mind boggling is that the NXP LDO works as expected with 1.2V -- these should be drop in replacements? I must be doing something wrong, obviously.
The ST 1.2V part has a minimum load current of 10mA, hence the need for the 120 ohm resistor if you can't guarantee that it will always have at least that load. There are several alternative SOT223 parts available without this restriction (and most of them don't need such a large output capacitor). However, the ones I have found all have different pinouts, so you would need to change the PCB layout.
dc42:
Ah ha! That's it -- missed that detail. The circuit will have at least a 10mA load for sure -- so I should be fine. It startled me to see a no load measure of 2.65V when I was expecting 1.2V.
