Hello.
I understand that this sounds like an unbelievably simple idea, and so I thought it would be. I have successfully written this first code, that detects an RFID tag and sounds a beep, but I am struggling with getting the second to work. Any ideas?
First Code -- this one WORKS!
This is a sample code for RDM630 RFID reader by Spekel(Spekel.se)
This work is licensed under a Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License.
http://creativecommons.org/licenses/by-nc-sa/3.0/
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
#define SPKR 7
char code[20];
int val = 0;
int bytesread = 0;
//create a Serial object RFID
SoftwareSerial RFID= SoftwareSerial(rxPin, txPin);
Serial.println("Serial Port Activated");
RFID.begin(9600);
Serial.println("RFID Reader Activated");
Serial.println("Scanning...");
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
pinMode(SPKR, OUTPUT);
val = 0;
bytesread = 0;
while(bytesread < 12)
// read 12 digit code
val = RFID.read();
if(val == 3)
{ // if header or stop bytes before the 10 digit reading
break; // stop reading
if(val != 2)
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
code[bytesread] = '\0'; // add the NULL
if(bytesread >= 12)
{ // if 12 digit read is complete
Serial.print("RFID Detected - Tag: [");
for(int i=0; code[i]!='\0' ; i++)
Serial.print(code[i]);
Serial.println("]"); //print the whole 13 bytes
for (int i=0; i<200; i++) { // generate a 1KHz tone for 1/2 second
digitalWrite(SPKR, HIGH);
delayMicroseconds(300);
digitalWrite(SPKR, LOW);
--- You didn't even need that but I assume you understand the setup now ---
The second code is exactly the same, apart from it contains and LDR that decides whether or not the value it receives has changed enough to sound the alarm and does so, allowing the alarm to be deactivated by an RFID.
This does NOT check to see if the RFID tag is the correct one, that is to be written in later. At the moment I get a constant beeping whether or not the RFID tag is used to dissarm, or there is no beep at all. Any ideas??
^^ Please actually read this before answering my Question!!
#define SPKR 7
#define rxPin 2
#define txPin 3
char code[20];
int val = 0;
int bytesread = 0;
int lightPin = 1;
int variable = 0;
int secondVariable = 0;
int differenceVariable = 0;
int ledPin = 13;
// --- Initiation Complete ---
RFID.begin(9600);
variable = analogRead(lightPin);
// --- Setup Complete ---
Serial.println(variable);
delay(50);
secondVariable = analogRead(lightPin);
differenceVariable = variable - secondVariable;
if ((differenceVariable^2) > 200) {
val = 0;
bytesread = 0;
while(bytesread < 12) { // read 12 digit code
val = RFID.read();
if(val == 3) { // if header or stop bytes before the 10 digit reading
if(val != 2) {
if(bytesread >= 12) { // if 12 digit read is complete
for(int i=0; code[i]!='\0' ; i++) {
Thank you very much for any help that you can give,
AMouse197
(I accidentally posted this in the wrong forum so have moved it)
