Hi guys,
Trying to run a continuous servo for a specific amount of time based on a reading from the LDR. Purpose is to open a door if LDR reading is above specified condition and then close it if the reading is below specified condition. The values I have in there right now are just preliminary so that doesn't matter at the moment.
What I need: loop needs to run once for the first statement, and then stop until the second condition is met.
Problem: I think the problem is that it keeps looping and reattaching the servo even after the detach.
How can I make the loop run only once until the condition changes to above or below the specified value.
Side note: When I block the LDR it changes the condition. So I believe the only issue is controlling the loop only once, until the condition changes.
Here's the code:
#include <Servo.h>
Servo servo1;
servo1.attach(9);
int lightValue = analogRead(A0);
if (lightValue < 600){
servo1.attach(9);
servo1.writeMicroseconds(1600);
servo1.detach();
else if (lightValue > 750){
servo1.attach(9);
servo1.writeMicroseconds(1000);
delay(10000);
servo1.detach();
