Thank’s in advance for your time, I’m a relative beginner with this, and this is my first post.
I am trying to get 6 ldrs to control six pots/faders within a chosen DAW.
I’m working with 1 ldr for now with an uno, with a 1k resistor.
With the simple code below I know that everything is working in the hardware, as I can view numbers relating to light in the serial monitor.
void setup(){
delay(100);
Serial.println(analogRead(0),DEC);
I have a second code I am using (which I’ll show under this paragraph), which runs through the SM and triggers in the DAW the midi value I specify in the top line - it works which is great.
What I am trying to find an answer to though, is that I’d like the numbers not to be on/off, but incrementally rise as the light intensity goes up. And I am at a loss with how to achieve that - the code below seems to trigger within an incredibly tight band of light intensity. Will the code I’m using be a good starting point, or should I look elsewhere? Apologies if I’m asking a silly question, and please let me know if I need to provide more details or am not being clear. Here’s the code I’m using.
unsigned char PadNote[40] = {21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60}; // MIDI notes from 0 to 127 (Mid C = 60)
// Imagine a piano roll. 45 55 are keys located on the middle for example.
// Tweak it to what sounds better to you.
int CutOff = 40; // This is the minimal amount of analog reading before triggering the note!
int MaxPlayTime[6] = {6500,6500,6500,6500}; // Cycles before a 2nd hit is allowed
// Best value after lots of trial and error.
#define midichannel 0; // MIDI channel from 0 to 15 (+1 in "real world")
// Internal Use Variables
// You should tweak here if it's not optimal yet.
// Those values work perfectly when using the small LDR and 1K Resistor. So used it!
boolean activePad[6] = {0,0,0,0}; // Array of flags of pad currently playing
int PinPlayTime[6] = {0,0,0,0}; // Counter since pad started to play
int ActivePadMinTime = 100;
int PinPauseTimeDelay = 200;
int PinPauseTime[4] = {0,0,0,0};
int PinAvailable[4] = {1,1,1,1};
unsigned char status;
int pin = 0;
int hitavg = 0;
int maxread = 0;
int debug = false;
int noteOffset = 0;
// Setup
Serial.begin(57600); // connect to the serial port 57600
// Main Program
for(int pin=0; pin <= 3; pin++)
hitavg = analogRead(pin); // read the input pin
if(debug)
Serial.println(hitavg);
if(hitavg < CutOff) {
if(debug)Serial.println("hitavg < CutOff");
if(activePad[pin] == false) {
if(debug) Serial.println("activePad[pin] == false");
if(PinAvailable[pin] == true)
if(debug) Serial.println("PinAvailable[pin] == true");
// Toca a nota full
activePad[pin] = true;
PinPauseTime[pin] = 0;
MIDI_TX((0x90 | pin), PadNote[pin]+noteOffset, 127);
if(debug) Serial.println("NoteON");
if(activePad[pin] == true) {
if(debug)Serial.println("activePad[pin] == true");
PinPlayTime[pin] += 1;
if(analogRead(pin) > CutOff && PinPlayTime[pin] > ActivePadMinTime)
if(debug) Serial.println("analogRead(pin) > PadCut == TRUE");
activePad[pin] = false;
PinAvailable[pin] = 2;
if(debug)
Serial.println("NoteOFF, available is now false. active is false;");
MIDI_TX((0x80 | pin), PadNote[pin]+noteOffset, 50);
PinPlayTime[pin] = 0;
if(PinAvailable[pin] == 2 && PinPauseTime[pin] > PinPauseTimeDelay) {
if(debug)Serial.println("PinAvailable[pin] == false && PinPauseTime[pin] > 10");
PinAvailable[pin] = true;
} else if(PinAvailable[pin] == 2) {
if(debug)Serial.println("PinPauseTime[pin] += 1;");
if(debug)delay(1000);
// Transmit MIDI Message
void MIDI_TX(uint8_t MESSAGE, uint8_t PITCH, uint8_t VELOCITY)
//status = MESSAGE + midichannel;
//status = MESSAGE + pin;
digitalWrite(13,HIGH);
Serial.write(MESSAGE);
Serial.write(PITCH);
Serial.write(VELOCITY);
delay(30);
digitalWrite(13,LOW);
