I keep having trouble understanding what it is I need to do in order to get my LDR to send a light value range to unity and then have Unity do something with that data.
I can get it to work a little but not the way I want.
Basically I’m trying to get my LDR on the Arduino to be able to send to Unity and then have unity do this:
at the bright side of the LDR range have it do something.
at the darkness range of the LDR have unity do something.
I’ll provide both of my codes which are getting a bit convoluted with all the rewrites and commented out stuff.
Arduino code here:
int lightPin = 0; //Define Pin For Photoresistor
int lightInt = 0;
//int lightLevel = analogRead(0);
//int threshold = 250;
//int range = 50;
const byte rLed = 12; //Sets Pin number LED is conneted too
const byte rLed2 = 1;
const byte yLed = 11;
const byte gLed = 10;
const byte gLed2 = 5;
const byte gLed3 = 4;
const byte wLed = 3;
const byte bLed = 2;
const byte bLed2 = 13;
char myChar; //changed the name of this variable because they are not all colurs now
const byte pulsePins[] = {6, 7, 8, 9}; //pins for a pulse output
char pulseTriggers[] = {'p', 'q','R','L'};
const int NUMBER_OF_PULSE_PINS = sizeof(pulsePins);
unsigned long pulseStarts[NUMBER_OF_PULSE_PINS];
unsigned long pulseLength = 500;
//Serial.begin (9600);
Serial.begin (115200);
Serial.setTimeout(13); //Added today Sun Nov 22 ( not sure if this is needed? )
pinMode(wLed, OUTPUT);
pinMode(rLed, OUTPUT);
pinMode(rLed2, OUTPUT);
pinMode(yLed, OUTPUT);
pinMode(gLed, OUTPUT);
pinMode(gLed2, OUTPUT);
pinMode(gLed3, OUTPUT);
pinMode(bLed, OUTPUT);
pinMode(bLed2, OUTPUT);
digitalWrite(wLed, LOW);
digitalWrite(rLed, LOW);
digitalWrite(rLed2, LOW);
digitalWrite(yLed, LOW);
digitalWrite(gLed, LOW);
digitalWrite(gLed2, LOW);
digitalWrite(gLed3, LOW);
digitalWrite(bLed, LOW);
digitalWrite(bLed2, LOW);
for (int p = 0; p < NUMBER_OF_PULSE_PINS; p++)
pinMode(pulsePins[p], OUTPUT);
digitalWrite(pulsePins[p], LOW);
//Light Sensor
if((lightInt - analogRead(lightPin)) > 1500 || (lightInt - analogRead(lightPin)) < -50){
lightInt = analogRead(lightPin);
Serial.println(lightInt);
//read the current light level.
/*int lightLevel = analogRead(lightPin);
//If the light level is within our desired range, send it to Unity.
if(lightLevel > threshold - range && lightLevel < threshold + range)
Serial.println(lightLevel);
if (Serial.available()) //if serial data is available
int lf = 10;
myChar = Serial.read(); //read one character from serial
if (myChar == 'r') //if it is an r
digitalWrite(rLed, !digitalRead(rLed)); //Oil Slick Toggle
if (myChar == 'b')
digitalWrite(bLed, !digitalRead(bLed)); //Surveillance Mode Toggle
if (myChar == 'y')
digitalWrite(yLed, !digitalRead(yLed)); //Movie Player Toggle
if (myChar == 'g')
digitalWrite(gLed, !digitalRead(gLed)); //Auto Phone Toggle
if (myChar == '1')
digitalWrite(bLed2, !digitalRead(bLed2)); //Scanner Toggle
if (myChar == 'f')
digitalWrite(gLed2, !digitalRead(gLed2)); //Fog Lights Toggle
if (myChar == 'h')
digitalWrite(gLed3, !digitalRead(gLed3)); //Head Lights Toggle
if (myChar == 'H')
digitalWrite(wLed, !digitalRead(wLed)); //High Beams Toggle
//Rear Hatch Popper
if (myChar == pulseTriggers[p])
pulseStarts[p] = millis(); //save the time of receipt
digitalWrite(pulsePins[p], HIGH);
//Grappling Hook Launch
for (int q = 0; q < NUMBER_OF_PULSE_PINS; q++)
if (myChar == pulseTriggers[q])
pulseStarts[q] = millis(); //save the time of receipt
digitalWrite(pulsePins[q], HIGH);
//Auto Doors Right Pulse
for (int R = 0; R < NUMBER_OF_PULSE_PINS; R++)
if (myChar == pulseTriggers[R])
pulseStarts[R] = millis(); //save the time of receipt
digitalWrite(pulsePins[R], HIGH);
//Auto Doors Left Pulse
for (int L = 0; L < NUMBER_OF_PULSE_PINS; L++)
if (myChar == pulseTriggers[L])
pulseStarts[L] = millis(); //save the time of receipt
digitalWrite(pulsePins[L], HIGH);
//the following code runs each time through loop()
if (millis() - pulseStarts[p] >= pulseLength) //has the pin been HIGH long enough ?
digitalWrite(pulsePins[p], LOW); //take the pulse pin LOW
if (millis() - pulseStarts[q] >= pulseLength) //has the pin been HIGH long enough ?
digitalWrite(pulsePins[q], LOW); //take the pulse pin LOW
I was not able to post my Unity Code so maybe I can do that in another reply if someone is willing to help?
