Hi everybody,
I was playing around with some parts and wanted to use an Arduino Mega2560 R3 in combination with a 74HC595 IC and a DS1307 Real-Time-Clock module to display the time on a 5641AS 4-digit 7-segment display.
All in all the code (see below) is working but I couldn't figure out how to reliably show leading zeros without messing up the time display when there are not needed.
I.e.: 3:05 PM is currently shown as 15 5 instead of 1505.
Here's the code. I'm still pretty new to this whole thing and it is rather frankenstein'ed together from different sources, so bear with me:
#include <Wire.h>
#include <DS3231.h>
DS3231 clock;
RTCDateTime dt;
int latch = 3; //74HC595 pin 9 STCP
int clocksh = 4; //74HC595 pin 10 SHCP
int data = 2; //74HC595 pin 8 DS
unsigned char table[] = { 0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f, 0x77, 0x7c, 0x39, 0x5e, 0x79, 0x71, 0x00 }; //Display digital data
const int nbrDigits = 4; // the number of digits in the LED display
//dig 0 1 2 3
const int digitPins[nbrDigits] = { 5, 6, 7, 8 };
clock.begin();
clock.setDateTime(__DATE__, __TIME__);
//Configuring output pins for the 74HC595
pinMode(latch, OUTPUT);
pinMode(clocksh, OUTPUT);
pinMode(data, OUTPUT);
//Configuring output pins for common cathod of each 7 segment digit
for (int i = 0; i < nbrDigits; i++) {
pinMode(digitPins[i], OUTPUT);
digitalWrite(digitPins[i], HIGH);
dt = clock.getDateTime();
DisplayHours(dt.hour);
DisplayMinutes(dt.minute);
delay(1);
void DisplayHours(int hour) {
if (hour == 0) {
DisplayDigit(0, 0); // display 0 in digit 0 (leftmost digit)
DisplayDigit(0, 1); // didplay 0 in digit 1
// display the value corresponding to each digit
for (int digit = 1; digit >= 0; digit--) {
if (hour > 0) {
DisplayDigit(hour % 10, digit);
hour = hour / 10;
void DisplayMinutes(int minute) {
if (minute == 0) {
DisplayDigit(0, 2); // display 0 in digit 2
DisplayDigit(0, 3); // display 0 in digit 3 (rightmost digit)
for (int digit = 3; digit >= 2; digit--) {
if (minute > 0) {
DisplayDigit(minute % 10, digit);
minute = minute / 10;
//Function to display on one seven segments digit
void DisplayDigit(unsigned char num, int digit) {
digitalWrite(latch, LOW);
shiftOut(data, clocksh, MSBFIRST, table[num]);
digitalWrite(latch, HIGH);
digitalWrite(digitPins[digit], LOW);
delay(4);
digitalWrite(digitPins[digit], HIGH);
