Learn IR remote
Hello, I have a problem sending the IR code from Arduino. The program works on the principle that when the button (9) is held down, the programming mode is switched on and if I press another button(7,8,10,11), I can reprogram it with a code from the IR receiver. When I release the button, I can send this recorded code via the IR diode transmitter. But there is a problem and it is still cycling. But when I turn off sending code to the IR diode (//IRS.sendNEC(codes[index],32);), but I send it to (Serial.print), it works all right without cycles.
#include <IRremote.h>
const byte IR_pin = A5;
IRrecv IRR (IR_pin);
IRsend IRS;
unsigned long int codes[4];
  pinMode(9, INPUT_PULLUP);
  pinMode(10, INPUT_PULLUP);
  pinMode(11, INPUT_PULLUP);
  pinMode(7, INPUT_PULLUP);
  pinMode(8, INPUT_PULLUP);
  pinMode(13, OUTPUT);
  Serial.begin (9600);
  IRR.enableIRIn ();
  if (digitalRead(9) == LOW)
    Serial.println("Programing buttons");
    digitalWrite(13, HIGH);
    while (digitalRead(9) == LOW)
      if (digitalRead(7) == LOW)
        Serial.println("Programming to button 7");
        Recieve(0);
      else if (digitalRead(8) == LOW)
        Serial.println("Programming to button 8");
        Recieve(1);
      else if (digitalRead(10) == LOW)
        Serial.println("Programming to button 10");
        Recieve(2);
      else if (digitalRead(11) == LOW)
        Serial.println("Programming to button 11");
        Recieve(3);
    Serial.println("End of Programing buttons");
    digitalWrite(13, LOW);
  if (digitalRead(9) == HIGH)
    while (digitalRead(9) == HIGH)
        Serial.println("Sending from button 7");
        Sending(0);
        Serial.println("Sending from button 8");
        Sending(1);
        Serial.println("Sending from button 10");
        Sending(2);
        Serial.println("Sending from button 11");
        Sending(3);
void Recieve(byte index)
  decode_results IR_data;
  if (IRR.decode (&IR_data))
    codes[index] = IR_data.value;
    IRR.resume ();
    Serial.println(String(index) + " is: " + String(codes[index], HEX));
    blink(2);
void Sending(byte index)
    String target = String(codes[index], HEX);
    target.toUpperCase();
    target = "0x" + target;
  delay(200);
void blink(byte count)
  for (byte i = 0; i < count; i++)
    delay(100);
    delay(100);
You act on buttons, while they are pressed, not when they become pressed.
Look into the state change example, or use a button library like Bounce2,
that handles bouncing and state change detection.
When i Touch down button(9)=> programming mode is ON
When i Touch up button(9)=> programming mode is OFF
You are repeatedly calling Receive(n) or Send(n) for as long as a button (7,8,10, or 11) is LOW. When you start the programming of a button you should probably wait until you receive the signal:
  while (!IRR.decode (&IR_data)) {}
It is still cycled
Fisrt try it work(When i press button(9) programming mode is on, and when i press some of buttons(for example 7) i can rewrite ir code on this button(7). When i Touch down button (9), programminfg mode is OFF and when i click button(7) it send rewrote code. ) but when i want try it again with some other button, it wont recieve new code to button.image
That could mean that only button 7 is wired correctly. Check the wires.
