https://lastminuteengineers.com/creating-esp32-web-server-arduino-ide
/* Put IP Address details, manually */
IPAddress local_ip(192,168,1,1);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
WiFi.softAP(ssid, password);
WiFi.softAPConfig(local_ip, gateway, subnet);
Is it possible to change this example:
So that the IP address, gateway and subnet mask don't need to be manually entered as they have it?
I'm a bit thrown because the one above is not automatically used for an IP address--unlike other examples:
https://microcontrollerslab.com/esp32-soft-access-point-web-server-in-arduino-ide/
Serial.print("Setting soft access point mode");
IPAddress IP = WiFi.softAPIP();
Yet, both of these examples use the same WiFi library. Is the bottom code all that's needed?
