Learning Arrays Question
Hi everyone.
I am trying to learn how to use and incorporate arrays into my code, but I don’t think I have a 100% handle on it yet.
The following is an array that I have been trying to write, but I am not getting results that I would suspect.
I set up the array pin numbers
in void set up I set all pins in array to OUTPUTS
and use a digitalWrite to set all pins HIGH
I then have a function to load the Outlet_Screen and call the Outlet_Status function.
The Outlet_Status is used to digitalRead the array, and then draw a fillCircle either green or red dependent upon whether the pin is HIGH or LOW.
The results that I would expect is when I navigate to the Outlet Screen all fillCircles would be drawn green since they are all set HIGH in void setup().
However, I am getting no results at all. No fillCircles are being drawn and screen remains blank.
I have tried it various ways, but have not yet figured out my issue.
Any help locating where I have gone wrong would be appreciated. Thank you!
int OUTLETS[8] ={A8,A9,A10,A11,A12,A13,A14,A15};                    //set the pins in the array
void setup(){
for (int on=0; on<7; on++) pinMode(OUTLETS[on], OUTPUT);        //array sets outlet box pins as outputs
for (int on=0; on<7; on++) digitalWrite(OUTLETS[on], HIGH);       //array sets outlet pins HIGH/ON
void Outlet_Screen(){
   Outlet_Status();
   myGLCD.loadBitmap(0,0,240,252, "OUTLETS.raw");       //loads outlet screen
   myGLCD.setColor(0,0,255);
   myGLCD.drawRoundRect(8,309,231,255);                      //Draw Clock Button
 void Outlet_Status(){                      //Function indicates power status with Green or Red light
   if (outlet_screen == true){
   for (int on=0; on<7; on++) digitalRead(OUTLETS[on]);
   if (OUTLETS[0] == HIGH){
   myGLCD.setColor(0,255,0);           //outlets are default "ON"
   myGLCD.fillCircle(101,51,11);       //Green Fill Circles will indicate this
   else if (OUTLETS[0] == LOW){
   myGLCD.setColor(255,0,0);           //outlet "OFF"
   myGLCD.fillCircle(101,51,11);       //Red Fill Circle will indicate this
   if (OUTLETS[1] == HIGH){
   myGLCD.fillCircle(101,94,11);
   else if (OUTLETS[1] == LOW){
   if (OUTLETS[2] == HIGH){
   myGLCD.fillCircle(101,137,11);
   else if (OUTLETS[2] == LOW){
   if (OUTLETS[3] == HIGH){
   myGLCD.fillCircle(101,181,11);
   else if (OUTLETS[3] == LOW){
   if (OUTLETS[4] == HIGH){
   myGLCD.fillCircle(222,51,11);
   else if (OUTLETS[4] == LOW){
   if (OUTLETS[5] == HIGH){
   myGLCD.fillCircle(222,95,11);
   else if (OUTLETS[5] == LOW){
   if (OUTLETS[6] == HIGH){
   myGLCD.fillCircle(222,137,11);
   else if (OUTLETS[6] == LOW){
   if (OUTLETS[7] == HIGH){
   myGLCD.fillCircle(222,181,11);
   else if (OUTLETS[7] == LOW){
void loop(){
      if (settings_screen == true){
        if((y<=166) && (y>=121)){
        if((x<=222) &&(x>=177)){
          waitForIt(177,121,222,166);
          x=0;
          y=0;
          settings_screen = false;
          outlet_screen = true;
          Outlet_Screen();
There are eight elements in your array - did you mean to miss off the last one?
No. I didn't mean to leave it off.
I had originally set it to 8, however when it didn't work the first time I had changed it to 7. My thinking was that the first index was zero[0].
The first index is zero, and the last index of an eight element array is seven.
Read the pin and discard the result.
Not good.
I have changed it back to 8. I started to confuse myself when I was trying to manipulate the code to get the desired result.
Besides that error the arrays seem proper??
Perhaps I should be looking in my status function with a problem in the if & else if statements.
Does it seem likely that A0 has the same value as HIGH (1)?
Not good.
Ah. Ok. I guess I don't understand how it is discarding the result.
Should I remove that for loop, and digitalRead each?
I was trying to be efficient
AWOL:
I couldn't be sure without completely guessing.
When you say HIGH(1) are you referring to HIGH(1) and LOW would then be LOW(0)?
OUTLETS [0] has the value A0.
That is never ever going to be equal to one.
OK, put it this way - where do you think the value returned by the digitalRead is going to end up?
AWOL:
I think I'm starting to see. I need to store or direct the read?
something like:
outletState = digitalRead(OUTLETS[on]);
where outletState is where the digitalRead ends up?
something like:
If you call that in a loop, outletState will contain the state of the last pin in the array. You need an array of states, too.
outletState[on] = digitalRead(OUTLETS[on]);
PaulS:
something like:
Thank you both so much! It's starting to sink in.
I've been making some progress, and have it producing the results I would like. However, the code is not that efficient. Before you clued me in on needing an outletState array as well I wrote a digitalRead of every index = to outletState
Example:
outletState = digitalRead(OUTLETS[0]);
if (outletState == HIGH){
else if (outletState == LOW){
and then to the next if & else if
outletState = digitalRead(OUTLETS[1]);
and so on through the index.
Now I can try slimming it down a bit.
Thanks to you both!!
