In using the DS18B20 for a couple of projects I have mostly used software snippets from others, accepting the compromises that entails; but now it's about time I took control and wrote my own code to get the best out of them.
I have read the datasheet from Maxim, though I confess I didn't understand much of it. It did prompt a few questions, and I hope you learned folk will help me with them.
The CONVERT command. Does issuing this command make every DS18B20 on the network do a temperature conversion?
During conversion would the network be 'tied-up' until the last sensor had finished?
//Background: I want to use 6 sensors, five at 10 bit resolution, one at 12 bit. -
Once conversion had finished would each hold its value in its scratchpad area? If no further commands were issued by the master would that value be held (almost) permanently?
Is it practical to issue a more frequent CONVERT command to an individual sensor? In doing this would all the remaining sensors retain their last readings in their scratchpads?
//Background. One sensor is used in a control loop, and needs 0.1 C resolution (so 12 bits) and to be reliably read and acted upon every 2 seconds. The other 5 sensors are room air temperature only, 0.5C resolution, and may be read much less frequently (9 bits). -
The datasheet makes claims of suitability for 'industrial applications'. Does this imply they will tolerate noisy electrical environments, and operate reliably over tens of metres of cable?
TIA
GM
