I want to add a UI menu and shown on OLED for the IOT logger project.
I had reviewed a lot of menu sample coding (eg: menu using encoder , software creating menu) , but still feel different to merge the coding into my project...
Is that any path/ material to learning UI design for arduino? ( design logic, method etc).
(Seems related material is lacking, or wrong keyword was search....)
Not really, because every project menu is different. You will probably discover that most of the menu code you find does not do what you want, and is hard to modify.
I've just roughed this out real quick.... But I've had relative success in the past a linked lists approach... (well, multi-linked lists anyway!).
Something approximating this:
#include "KTS_Button.h"
KTS_Button buttons[] = { 22, 23, 24, 25, 9 };
const byte NUM_BTNS = sizeof(buttons) / sizeof(buttons[0]);
LiquidCrystal_I2C lcd(0x27, 16, 2);
class MenuItem {
public:
const char * title;
MenuItem *parent = nullptr;
MenuItem *prev = nullptr;
MenuItem *next = nullptr;
MenuItem *child = nullptr;
MenuItem(const char * title)
: title(title) {}
void display() {
lcd.clear();
if (parent) {
lcd.setCursor(0, 0);
lcd.print("# ");
lcd.print(parent->title);
lcd.print(" #");
lcd.setCursor(0, 1);
lcd.print(title);
MenuItem *currentMenu;
MenuItem mainMenu = { "Main Menu" };
MenuItem l1_MenuOne = { "1) Menu One L1" }; // Level One Menu Item
MenuItem l1_MenuTwo = { "2) Menu Two L1" };
MenuItem l2_MenuOne = { "1) Menu One L2" }; // Level Two Menu Item
MenuItem l2_MenuTwo = { "2) Menu Two L2" };
Serial.begin(115600);
lcd.init();
lcd.backlight();
mainMenu.child = &l1_MenuOne;
l1_MenuOne.parent = &mainMenu;
l1_MenuOne.next = &l1_MenuTwo;
l1_MenuTwo.prev = &l1_MenuOne;
l1_MenuTwo.parent = &mainMenu;
l1_MenuTwo.child = &l2_MenuOne;
l2_MenuOne.parent = &l1_MenuTwo;
l2_MenuOne.next = &l2_MenuTwo;
l2_MenuTwo.prev = &l2_MenuOne;
l2_MenuTwo.parent = &l1_MenuTwo;
currentMenu = &mainMenu;
currentMenu->display();
void handleMenuInput(byte buttonPressed) {
switch (buttonPressed) {
case 0:
if (currentMenu->child)
currentMenu = currentMenu->child;
case 1:
if (currentMenu->parent)
currentMenu = currentMenu->parent;
case 2:
if (currentMenu->prev)
currentMenu = currentMenu->prev;
case 3:
if (currentMenu->next)
currentMenu = currentMenu->next;
for (byte i = 0; i < NUM_BTNS; i++) {
if (buttons[i].read() == SINGLE_PRESS)
handleMenuInput(i);
The issues I've had so far are:
One, it's a bit of a waste to hold empty pointers where they are not needed (especially if you have a very large menu!) and two, writing out how everything is connected is messy, and very prone to typos/mistakes.
Adding function pointers or values and things to the menu items is pretty easy though! And it's a tested and working example. (The button class is my own, but any will do).
