Hello. I've written a simple program that increments a number and displays it in binary via 14 LEDs connected to pins 0-13 on the Arduino Leonardo. All but one LED displays the correct pattern. The least significant LED, connected to pin 0, remains off. Here's my code:
int number = 0;
int delayTime = 1000;
for (int thisPin = 0; thisPin < 13; thisPin++) {
pinMode(thisPin, OUTPUT);
int temp = number;
for (int thisPin = 13; thisPin > 0; thisPin--) {
if (temp - pow(2, thisPin) >= 0) {
temp -= pow(2, thisPin);
digitalWrite(thisPin, HIGH);
else {
digitalWrite(thisPin, LOW);
number++;
delay(delayTime);
Thanks. I fixed the code by changing a line from this:
to this:
for (int thisPin = 13; thisPin >= 0; thisPin--) {
I'm confused as to why that worked. I thought the original line would continue to decrement to the 0th pin because it would keep going while it's at a number greater than 0. (thisPin > 0)
It does keep going, decrementing until thisPin is 0. Since 0 is not greater than 0, the body of the for loop is then skipped.
You are still setting the mode of pins 0 to 12, and writing to pins 0 to 13. That can't be right.
Oh, I think I understand now. The middle part of the for loop (in between the two semicolons) only captures the values it explicitly states, not also the next iteration. Here's the full corrected code for anyone with the same problems:
int number = 0;
for (int thisPin = 0; thisPin <= 13; thisPin++) {
int temp = number;
else {
number++;
delay(delayTime);
