Leave the loop
Hello I would like to be able to leave the loop when i send a 0. But it doesn’t work. How do i do this ???
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* ssid = "**********";
const char* password = "***********";
const char* mqtt_server = "mqtt-dashboard.com";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
#include "FastLED.h"
#define LED_PIN 4
#define NUM_LEDS 1
#define LED_TYPE    WS2812B
#define COLOR_ORDER GRB
#define BRIGHTNESS  255
CRGB leds[NUM_LEDS];
//CRGB leds[NUM_LEDS];
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  LEDS.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS);
  FastLED.setBrightness(BRIGHTNESS);
uint8_t gHue = 0;
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  payload[2]='\0';
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);}
switch (payload[0]) {
  case '1':{
    Serial.println("On");
    for (int i = 0; i < 2;) {
      for (int i = 0; i < 255; i++) {
      fill_solid(leds, NUM_LEDS, CHSV( gHue, 255, i));
      FastLED.show();
      delay(15);
      EVERY_N_MILLISECONDS(10) {gHue++;}
      Serial.println(payload[0]);
      if ((char)payload[0] == '0') {
       exit;}
      fill_solid(leds, NUM_LEDS, CHSV( gHue, 255, 255-i));
      FastLED.show();
      delay(15);
       exit;}
      //int pos = beatsin16(5,0,192); // generating the sinwave
      //fill_solid(leds, NUM_LEDS, CHSV( gHue, 255, pos)); // CHSV (hue, saturation, value);
      //FastLED.show();
      //EVERY_N_MILLISECONDS(10) {gHue++;}
      //Serial.println(pos);
      // Serial.println(i);
       i = 2;}
  break;}
  case '0': {
    Serial.println("Out");
    leds[0] = CRGB::Black;
    FastLED.show();
  break;}
  if (!client.connected()) {
    reconnect();}
  client.loop();
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str())) {
      Serial.println("connected");
      client.subscribe("PLANT/1");}
      else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
void setup_wifi() {
  delay(10);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");}
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
RGBBreathingESP8266.ino (3.14 KB)
exit;Try return instead.
"exit" by itself like that does nothing at all. (exit is a function, unlike return)
Doesn't work with return either.
TheRogueNinja:
Please tell us what "work" means to you.
Use as many words as you need.
Ok so, the esp8266 turns on and the led is bright white, then I send a 1 with mqtt and the esp8266 excutes the "rgb breathing" loop, then if i send a 0 the esp8266 doesn't see the 0 that I send (because either the delay or the loop, I think) and because it doesn't see the 0 that I send the led doesn't turn off. What I would like to know is how to register the 0 that I send via mqtt while being the loop.
also thank you for your help so far.
I wouldn't put a blocking loop in the callback - just implement the LED flashing as a state machine in the main loop, controlled by a simple flag set or reset in the callback.
