Toutes les infos sont dans le lien. Mais vous avez raison, je peux le reposter ici pour plus de clareté:
// ST7735 library example
// SD Media Player/File Viewer with File Browser
// Requires Arduino_ST7735_STM, SdFat, JpgDecoder_STM, RREFont libraries and stm32duino
// (C)2019-20 Pawel A. Hernik
// YouTube videos:
// https://youtu.be/6Uh5Iu-erO0
// https://youtu.be/o3AqITHf0mo
// https://youtu.be/4PwaX-zusPM
ST7735 128x160 1.8" LCD pinout (header at the top, from left):
#1 LED -> 3.3V
#2 SCK -> SCL/D13/PA5
#3 SDA -> MOSI/D11/PA7
#4 A0/DC -> D8/PA1 or any digital
#5 RESET -> D9/PA0 or any digital
#6 CS -> D10/PA2 or any digital
#7 GND -> GND
#8 VCC -> 3.3V
SPI2/SPI1
SD_SCK - PB13/PA5
SD_MISO - PB14/PA6
SD_MOSI - PB15/PA7
SD_CS - PB12/PA4
STM32 SPI1/SPI2 pins:
SPI1 MOSI PA7
SPI1 MISO PA6
SPI1 SCK PA5
SPI1 CS PA4
SPI2 MOSI PB15
SPI2 MISO PB14
SPI2 SCK PB13
SPI2 CS PB12
Features:
- SD file browser with one button
- Short click for next file/switch stat mode
- Long click to show file or exit the viewer
- Semi-transparent progress bar
- Long file names (up to 23 characters fit on the screen) and file size displayed
- Supported file types: RAW 565 video, BMP, JPEG, TXT (very simple)
Comments:
- SD uses faster STM32 SPI1 interface which supports 36 Mbps
- SPI1 is shared between LCD and SD card
- Not all SD cards work at 36MBps
- Fast card at 36Mbps gives 41fps for 160x128 video
- SdFat library uses DMA for SPI transfer
- Big buffer in RAM is used to speed up SPI/DMA transfer
- fast JPEG decoding - for 160x128 pixel images - 100 ms or less
#include <SPI.h>
#include <Adafruit_GFX.h>
#if (__STM32F1__) // bluepill
#define TFT_CS PA2
#define TFT_DC PA1
#define TFT_RST PA0
#include <Arduino_ST7735_STM.h>
#else
#define TFT_CS 10
#define TFT_DC 8
#define TFT_RST 9
//#include <Arduino_ST7735_Fast.h>
#endif
#define SCR_WD 160
#define SCR_HT 128
Arduino_ST7735 lcd = Arduino_ST7735(TFT_DC, TFT_RST, TFT_CS);
#define NLINES 32
#define BUF_WD 160
uint16_t buf[BUF_WD*NLINES] __attribute__((aligned(4)));
char txt[30];
#include "RREFont.h"
#include "rre_5x8.h"
RREFont font;
// renders directly to LCD
void customRect(int x, int y, int w, int h, int c) { lcd.fillRect(x, y, w, h, c); }
// renders to the buffer
void customRectBuf(int x, int y, int w, int h, int c)
if(y>NLINES) return;
if(y+h>NLINES) h=NLINES-y;
for(int j=0;j<h;j++) for(int i=0;i<w;i++) buf[(y+j)*BUF_WD+x+i]=c;
#include "SdFat.h"
#define USE_SDIO 0
//const uint8_t SD_CS = PB12;
//SdFat sd(2);
const uint8_t SD_CS = PA4;
SdFat sd(1);
SdFile file;
// use 18 if your SD card doesn't work
#define SD_SPEED 36
//#define SD_SPEED 18
void sdSPI() { SPI.beginTransaction(SD_SCK_MHZ(SD_SPEED)); }
void lcdSPI() { SPI.beginTransaction(SPISettings(36000000, MSBFIRST, SPI_MODE3, DATA_SIZE_16BIT)); }
// Required for JPEG loading from SD card and rendering
// define USE_SDFAT_LIBRARY in JpgDecoder_STM.h too
#include <JpgDecoder_STM.h>
// the callback function below renders decoded JPEG on the LCD
bool renderLCD(int16_t x, int16_t y, uint16_t w, uint16_t h, uint16_t* bitmap)
lcdSPI();
if(y>=lcd.height()) return 0; // 0 - to stop decoding
lcd.drawImage(x,y, w,h, bitmap);
return 1; // 1 - to decode next block
// align to a 32 bit boundary for the best performance
#define DECODE_BUFFER_LEN 3100
//uint8_t decodeBuffer[DECODE_BUFFER_LEN] __attribute__((aligned(4)));
JpgDecoder jpeg(renderLCD,(uint8_t*)buf,DECODE_BUFFER_LEN);
#define BUTTON PB9
int buttonState;
int prevState = HIGH;
long btDebounce = 30;
long btMultiClick = 600;
long btLongClick = 500;
long btLongerClick = 2000;
long btTime = 0, btTime2 = 0;
int clickCnt = 1;
// 0=idle, 1,2,3=click, -1,-2=longclick
int checkButton()
int state = digitalRead(BUTTON);
if( state == LOW && prevState == HIGH ) { btTime = millis(); prevState = state; return 0; } // button just pressed
if( state == HIGH && prevState == LOW ) { // button just released
prevState = state;
if( millis()-btTime >= btDebounce && millis()-btTime < btLongClick ) {
if( millis()-btTime2<btMultiClick ) clickCnt++; else clickCnt=1;
btTime2 = millis();
return clickCnt;
if( state == LOW && millis()-btTime >= btLongerClick ) { prevState = state; return -2; }
if( state == LOW && millis()-btTime >= btLongClick ) { prevState = state; return -1; }
return 0;
int prevButtonState=0;
int handleButton()
prevButtonState = buttonState;
buttonState = checkButton();
return buttonState;
void error(char *err, uint16_t col, int8 halt=1)
lcdSPI(); lcd.fillScreen(col);
font.setColor(YELLOW);
font.setFillRectFun(customRect);
font.setBold(1);
font.setSpacingY(4);
font.printStr(4,4,err);
font.setBold(0);
if(halt) sd.errorHalt(err); else Serial.println(err);
int statMode=1; // 0-0ff, 1-progress, 2-full, 3-fps
void darken(uint16_t *p)
uint16_t c = *p;
int r,g,b;
r = (c>>8)&0xf8;
g = (c>>3)&0xfc;
b = (c<<3)&0xf8;
//*p = RGBto565(r/2,g/2,b/2); // blend to black
*p = RGBto565(r+(60-r)/2,g+(60-g)/2,b+(60-b)/2); // blend to dark grey
void drawProgress(int y, int p)
int i;
for(i=0; i<p; i++) buf[10+(y+0)*BUF_WD+i]=buf[10+(y+1)*BUF_WD+i]=buf[10+(y+2)*BUF_WD+i]=buf[10+(y+3)*BUF_WD+i]=RED;
//for(i=p; i<140; i++) buf[10+5*BUF_WD+i]=buf[10+6*BUF_WD+i]=buf[10+7*BUF_WD+i]=buf[10+8*BUF_WD+i]=RGBto565(120,120,120);
for(i=p; i<140; i++) {
darken(&buf[10+(y+0)*BUF_WD+i]);
darken(&buf[10+(y+1)*BUF_WD+i]);
darken(&buf[10+(y+2)*BUF_WD+i]);
darken(&buf[10+(y+3)*BUF_WD+i]);
// Params:
// filename - file name
// x,y - start x,y on the screen
// wd,ht - width, height of the video (raw data has no header with such info)
// nl - num lines read in one operation (nl*wd*2 bytes are loaded)
// skipFr - num frames to skip
int showVideo(char *filename, int wd, int ht, int nl, int skipFr)
sdSPI();
if(!file.open(filename, O_CREAT | O_RDONLY)) {
snprintf((char*)buf,100,"Cannot open\n%s\n",filename);
error((char*)buf,BLUE,0);
//return -1;
file.seekSet(0);
unsigned long sdStartTime,frTime,lcdTime,sdTime=0,statTime=0,statStartTime;
handleButton();
while(file.available()) {
sdTime = statTime = 0;
frTime = millis();
for(int i=0;i<ht/nl;i++) {
sdStartTime = millis();
int rd = file.read(buf,wd*2*nl);
sdTime += millis()-sdStartTime;
statStartTime = millis();
if(i==(ht/nl)-1 && NLINES>=8 && statMode>0) {
if(statMode==1) drawProgress(NLINES-8,140*(file.curPosition()/1000)/(file.fileSize()/1000)); else
if(statMode>1) {
font.setFillRectFun(customRectBuf);
font.setColor(BLACK);
font.printStr(1,NLINES-6,txt);
font.printStr(2,NLINES-6,txt);
font.printStr(3,NLINES-6,txt);
font.printStr(1,NLINES-8,txt);
font.printStr(2,NLINES-8,txt);
font.printStr(3,NLINES-8,txt);
font.printStr(1,NLINES-7,txt);
font.printStr(3,NLINES-7,txt);
font.printStr(2,NLINES-7,txt);
statTime += millis()-statStartTime;
lcdSPI();
lcd.drawImage(0,i*nl,lcd.width(),nl,buf);
frTime = millis()-frTime-statTime;
lcdTime = frTime-sdTime;
if(buttonState>0) {
if(++statMode>3) statMode=0;
if(statMode==2) snprintf(txt,30,"Fr/SD/LCD: %2ld/%2ld/%2ld FPS:%2d",frTime,sdTime,lcdTime,1000/frTime);
if(statMode==3) snprintf(txt,30,"%2ld fps",1000/frTime);
if(skipFr>0) file.seekCur(wd*ht*2*skipFr);
if(handleButton()<0 && prevButtonState==0) break;
file.close();
while(handleButton()==0);
return 1;
// Limited to LCD resolution
int showBMP(char *filename)
int bmpWd, bmpHt, bmpBits, bmpNumCols, y=0;
uint16_t pal[256];
sdSPI();
lcdSPI(); lcd.fillScreen(YELLOW);
Serial.print(F("Cannot open "));
Serial.println(filename);
//return -1;
file.seekSet(0);
file.read(buf,54);
uint8_t *buf8 = (uint8_t *)buf;
bmpWd = buf8[18]+buf8[19]*256;
bmpHt = buf8[22]+buf8[23]*256;
bmpBits = buf8[28];
bmpNumCols = buf8[46]+buf8[47]*256;
//Serial.print(bmpWd); Serial.print(" x "); Serial.print(bmpHt); Serial.print(" x "); Serial.print(bmpBits); Serial.print(" bpp");
//if(bmpBits<=8) { Serial.print(" / "); Serial.print(bmpNumCols); Serial.print(" colors"); }
//Serial.println();
if(bmpBits<=8) {
file.read(buf,bmpNumCols*4);
for(int i=0;i<bmpNumCols;i++) pal[i]=RGBto565(buf8[2+i*4],buf8[1+i*4],buf8[i*4]);
while(file.available() && y<bmpHt) {
buf8 = (uint8_t *)buf+BUF_WD*2;
if(bmpBits==4) {
file.read(buf8,bmpWd/2);
for(int i=0;i<bmpWd/2;i++) {
buf[i*2+0] = pal[buf8[i]>>4];
buf[i*2+1] = pal[buf8[i]&0xf];
} else
if(bmpBits==8) {
file.read(buf8,bmpWd);
for(int i=0;i<bmpWd;i++) buf[i] = pal[buf8[i]];
file.read(buf8,bmpWd*3);
for(int i=0;i<bmpWd;i++) buf[i] = RGBto565(buf8[i*3+2],buf8[i*3+1],buf8[i*3+0]);
lcdSPI(); lcd.drawImage((lcd.width()-bmpWd)/2,lcd.height()-1-y,bmpWd,1,buf);
y++;
file.close();
while(handleButton()==0 || prevButtonState!=0);
return 1;
int showJPG(char *filename)
uint16_t jwd,jht,sc=0;
jpeg.getDim(&jwd,&jht,filename);
if(2*jht/lcd.height()>=15) sc=3; else // 15/2
if(2*jht/lcd.height()>=7) sc=2; else // 7/2
if(2*jht/lcd.height()>=3) sc=1; // 3/2
int x=(lcd.width()-(jwd>>sc))/2;
int y=(lcd.height()-(jht>>sc))/2;
if(x<0) x=0;
if(y<0) y=0;
snprintf(txt,50,"%4d x %4d sc=%d [%s]",jwd,jht,sc,filename);
Serial.println(txt);
jpeg.show(x,y,filename,sc);
return 1;
int showTxt(char *filename)
sdSPI();
//return -1;
file.seekSet(0);
int rd = file.read(buf,NLINES*BUF_WD*2);
char *txt = (char*)buf;
txt[rd-1]=0;
lcdSPI();
lcd.fillScreen(RGBto565(0,0,100));
font.setSpacingY(1);
font.setCR(1);
font.printStr(0,0,txt);
file.close();
return 1;
char *getExt(char *filename)
int len = strlen(filename);
return len>3 ? filename+len-3 : filename;
int checkExt(char *filename, char *ext)
return strcmp(getExt(filename),ext)==0;
// SD file browser data
#define MAX_NAME_LEN 23
#define MAX_DIR_LEN 50
#define MAX_SIZE_LEN 5
const int charWd = 6;
const int lineHt = 12;
const int numScreenFilesMax = 9;
int numScreenFiles = 0;
char filesList[numScreenFilesMax][MAX_NAME_LEN+1]; // last char filesList[MAX_NAME_LEN] is used as file/dir mode
char filesSize[numScreenFilesMax][MAX_SIZE_LEN];
int selFile = 0;
int fileAvailable = 1;
uint32_t dirPos;
bool rootDir = true;
char curDir[MAX_DIR_LEN];
int ys = 14, xs = 2;
void fileList(int rewind=0)
numScreenFiles = 0;
selFile = 0;
sdSPI();
if(rewind || !fileAvailable) {
dirPos = 0;
if(!rootDir) {
strcpy(filesList[numScreenFiles],"..");
filesList[numScreenFiles][MAX_NAME_LEN] = 2;
numScreenFiles++;
sd.vwd()->seekSet(dirPos);
while(numScreenFiles<numScreenFilesMax) {
fileAvailable = file.openNext(sd.vwd(), O_READ);
if(!fileAvailable) { file.close(); break; }
file.getName(filesList[numScreenFiles],MAX_NAME_LEN);
filesList[numScreenFiles][MAX_NAME_LEN-1] = 0;
//Serial.print(filesList[numScreenFiles]);
if(file.isDir()) {
//Serial.println("/");
if(checkExt(filesList[numScreenFiles],"raw") || checkExt(filesList[numScreenFiles],"txt") ||
checkExt(filesList[numScreenFiles],"bmp") || checkExt(filesList[numScreenFiles],"jpg"))
filesList[numScreenFiles][MAX_NAME_LEN] = 1;
filesList[numScreenFiles][MAX_NAME_LEN] = 0;
uint32_t fsize = file.fileSize();
if(fsize>1000*1000*1000) snprintf(filesSize[numScreenFiles],MAX_SIZE_LEN,"%dG",fsize>>30);
else if(fsize>1000*1000) snprintf(filesSize[numScreenFiles],MAX_SIZE_LEN,"%dM",fsize>>20);
else if(fsize>1999) snprintf(filesSize[numScreenFiles],MAX_SIZE_LEN,"%dK",fsize>>10);
else snprintf(filesSize[numScreenFiles],MAX_SIZE_LEN,"%dB",fsize);
filesSize[numScreenFiles][MAX_SIZE_LEN-1] = 0;
//Serial.print("\t\t"); Serial.println(filesSize[numScreenFiles]);
numScreenFiles++;
file.close();
dirPos = sd.vwd()->curPosition();
if(numScreenFiles>0) fileListShow();
uint16_t bgCol(int i)
return i&1 ? RGBto565(30,30,30) : RGBto565(50,50,50);
void selFrame(int i, uint16_t c)
lcdSPI();
lcd.drawRect(0,ys+i*lineHt,(MAX_NAME_LEN-1)*charWd+4,lineHt,c);
void selFrameActive()
selFrame(selFile,filesList[selFile][MAX_NAME_LEN] ? GREEN : RED);
void fileListShow()
lcdSPI(); lcd.fillScreen(BLACK);
lcd.drawFastHLine(0,0,lcd.width(),RGBto565(0,0,180));
lcd.drawFastHLine(0,ys-1,lcd.width(),RGBto565(0,0,180));
lcd.drawFastHLine(0,1,lcd.width(),RGBto565(0,0,200));
lcd.drawFastHLine(0,ys-2,lcd.width(),RGBto565(0,0,200));
lcd.drawFastHLine(0,2,lcd.width(),RGBto565(0,0,220));
lcd.drawFastHLine(0,ys-3,lcd.width(),RGBto565(0,0,220));
lcd.fillRect(0,3,lcd.width(),ys-6,BLUE);
font.printStr(xs,3,curDir);
for(int i=0;i<numScreenFiles;i++) {
lcd.fillRect(0,ys+i*lineHt,lcd.width(),lineHt,bgCol(i));
if(filesList[i][MAX_NAME_LEN]==2) {
font.printStr(xs+charWd,ys+2+i*lineHt,filesList[i]);
font.printStr(xs,ys+2+i*lineHt,"["); font.printStr(xs+6+strlen(filesList[i])*charWd,ys+2+i*lineHt,"]");
font.printStr(lcd.width()-3*charWd+1,ys+2+i*lineHt,"DIR");
font.setColor(filesList[i][MAX_NAME_LEN] ? WHITE : RGBto565(190,190,190));
font.printStr(xs,ys+2+i*lineHt,filesList[i]);
font.setColor(RGBto565(230,230,230));
font.printStr(lcd.width()-strlen(filesSize[i])*charWd+1,ys+2+i*lineHt,filesSize[i]);
int handleFile(char *filename)
if(checkExt(filename,"raw")) return showVideo(filename, 160,128, 32,0); else
if(checkExt(filename,"txt")) return showTxt(filename); else
if(checkExt(filename,"bmp")) return showBMP(filename); else
if(checkExt(filename,"jpg")) return showJPG(filename); else
return 0;
void setup(void)
pinMode(BUTTON, INPUT_PULLUP);
lcd.init();
lcd.setRotation(3);
font.init(customRect, SCR_WD, SCR_HT); // custom fillRect function and screen width and height values
font.setFont(&rre_5x8); font.setFontMinWd(5);
//delay(8000);
if(!sd.cardBegin(SD_CS, SD_SCK_MHZ(SD_SPEED)))
error("\nSD Card\ninitialization\nfailed.\n",RED);
if(!sd.fsBegin())
error("\nFile System\ninitialization\nfailed.\n",MAGENTA);
strcpy(curDir,"/stm32");
if(!sd.chdir(curDir)) strcpy(curDir,"/");
//showVideo("budlight_160x128.raw", 160,128, 32,0);
fileList(1);
selFrameActive();
void loop(void)
handleButton();
if(buttonState>0) {
selFrame(selFile,bgCol(selFile));
if(++selFile>=numScreenFiles) {
fileList();
if(numScreenFiles==0) fileList(1);
selFrameActive();
if(buttonState<0 && prevButtonState==0) {
if(filesList[selFile][MAX_NAME_LEN]==2) {
if(filesList[selFile][0]=='.') {
char *last = strrchr(curDir,'/');
if(last && last!=curDir) *last=0;
if(last==curDir) rootDir = true;
rootDir = false;
if(strlen(curDir)+strlen(filesList[selFile])+2<MAX_DIR_LEN) {
strcat(curDir,"/");
strcat(curDir,filesList[selFile]);
sd.chdir(curDir);
fileList(1);
selFrameActive();
} else
if(handleFile(filesList[selFile])) {
fileListShow();
selFrameActive();
