Led 8x8 Matrix Word Scroll not working
I’m currently attempting to use the code from this link:
http://home.comcast.net/~kkrausnick/arduino_projects/index.html
EDIT(Please note the author of the code does indeed state that it is free to use)
to test my Led Matrix on the Arduino Board I build. However, Once I happen to run the code the letter ’ H’ does not appear at all on my matrix, let alone the original here is the code and my circuit:
// Message to be displayed:
const char charMsg = “H”;
// Number of milliseconds to pause after message (0 = no pause):
unsigned const msgPauseTime = 2000;
// Controls the message scroll speed in ms (lower = faster):
const int scrollSpeed = 60;
// List of supported characters and index into corresponding character definitions array
const byte charSet = " ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789!#$%&’()*±,.~:;<>?@/\=_";
// Character definitions (8 bytes per character)
const byte charDef = {
0,0,0,0,0,0,0,0, // Space symbol (must be the first character in this array)
// Upper case letters:
24,60,102,126,102,102,102,0, // A
124,102,102,124,102,102,124,0, // B
60,102,96,96,96,102,60,0, // C
120,108,102,102,102,108,120,0, // D
126,96,96,120,96,96,126,0, // E
126,96,96,120,96,96,96,0, // F
60,102,96,110,102,102,60,0, // G
102,102,102,126,102,102,102,0, // H
60,24,24,24,24,24,60,0, // I
30,12,12,12,12,108,56,0, // J
102,108,120,112,120,108,102,0, // K
96,96,96,96,96,96,126,0, // L
99,119,127,107,99,99,99,0, // M
102,118,126,126,110,102,102,0, // N
60,102,102,102,102,102,60,0, // O
124,102,102,124,96,96,96,0, // P
60,102,102,102,102,60,14,0, // Q
124,102,102,124,120,108,102,0, // R
60,102,96,60,6,102,60,0, // S
126,24,24,24,24,24,24,0, // T
102,102,102,102,102,102,60,0, // U
102,102,102,102,102,60,24,0, // V
99,99,99,107,127,119,99,0, // W
102,102,60,24,60,102,102,0, // X
102,102,102,60,24,24,24,0, // Y
126,6,12,24,48,96,126,0, // Z
// Lower case letters:
0,0,60,6,62,102,62,0, // a
0,96,96,124,102,102,124,0, // b
0,0,60,96,96,96,60,0, // c
0,6,6,62,102,102,62,0, // d
0,0,60,102,126,96,60,0, // e
0,14,24,62,24,24,24,0, // f
0,0,62,102,102,62,6,124, // g
0,96,96,124,102,102,102,0, // h
0,24,0,56,24,24,60,0, // i
0,6,0,6,6,6,6,60, // j
0,96,96,108,120,108,102,0, // k
0,56,24,24,24,24,60,0, // l
0,0,102,127,127,107,99,0, // m
0,0,124,102,102,102,102,0, // n
0,0,60,102,102,102,60,0, // o
0,0,124,102,102,124,96,96, // p
0,0,62,102,102,62,6,6, // q
0,0,124,102,96,96,96,0, // r
0,0,62,96,60,6,124,0, // s
0,24,126,24,24,24,14,0, // t
0,0,102,102,102,102,62,0, // u
0,0,102,102,102,60,24,0, // v
0,0,99,107,127,62,54,0, // w
0,0,102,60,24,60,102,0, // x
0,0,102,102,102,62,12,120, // y
0,0,126,12,24,48,126,0, // z
// Numbers
60,102,110,118,102,102,60,0, // 0
24,24,56,24,24,24,126,0, // 1
60,102,6,12,48,96,126,0, // 2
60,102,6,28,6,102,60,0, // 3
6,14,30,102,127,6,6,0, // 4
126,96,124,6,6,102,60,0, // 5
60,102,96,124,102,102,60,0, // 6
126,102,12,24,24,24,24,0, // 7
60,102,102,60,102,102,60,0, // 8
60,102,102,62,6,102,60,0, // 9
// Characters and symbols
24,24,24,24,0,0,24,0, // !
102,102,255,102,255,102,102,0, // #
24,62,96,60,6,124,24,0, // $
98,102,12,24,48,102,70,0, // %
60,102,60,56,103,102,63,0, // &
6,12,24,0,0,0,0,0, // ’
12,24,48,48,48,24,12,0, // (
48,24,12,12,12,24,48,0, // )
0,102,60,255,60,102,0,0, // *
0,24,24,126,24,24,0,0, // +
0,0,0,126,0,0,0,0, // -
0,0,0,0,0,24,24,48, // ,
0,0,0,0,0,24,24,0, // .
60,66,165,129,165,153,66,60, // “Smiley face” replaces the tilde (~) character
0,0,24,0,0,24,0,0, // :
0,0,24,0,0,24,24,48, // ;
14,24,48,96,48,24,14,0, // <
112,24,12,6,12,24,112,0, // >
60,102,6,12,24,0,24,0, // ?
60,102,110,110,96,98,60,0, // @
60,48,48,48,48,48,60,0, // [
60,12,12,12,12,12,60,0, // ]
0,3,6,12,24,48,96,0, // /
0,96,48,24,12,6,3,0, //
0,0,126,0,126,0,0,0, // =
0,0,0,0,0,0,0,255 // _
const int colPins = {
2, 3, 4, 5, 6, 7, 8, 9}; // LED matrix columns are assigned to digital pins
const int clockPin = 11; // Connects to 4017 decade counter clock pin 14
const int resetPin = 10; // Connects to 4017 decade counter reset pin 15
unsigned long thisMs = 0; // Elapsed time in ms that Arduino has been running
unsigned long lastMs; // Interval since the message was last scrolled one column
unsigned long pauseStart; // Elapsed time in ms since end-of-message pause was started
int msgIdx = 0; // Keeps track of the message character current being scrolled
byte charBuffer[16]; // Scroll “window” consists of portions of current and next character
int bufferIdx = 0; // Keeps track of scrolling (after 8 columns, fetch next character)
boolean pauseDisplay = false; // Determines when scrolling should be paused
for (int i = 0; i < 8; i++)
pinMode(colPins*, OUTPUT); // LED matrix columns are controlled by 8 digital pins*
  • pinMode(clockPin, OUTPUT); // Clock pin on 4017 decade counter advances to the next row*
  • pinMode(resetPin, OUTPUT); // Reset pin on 4017 decade counter is triggered after 8 rows*
  • initialize(); // Prepare to start displaying banner message*
  • thisMs = millis(); // Get current time*
  • if (thisMs - lastMs > scrollSpeed) { // Time to scroll yet?*
  • lastMs = thisMs; // Yes, so save current time value*
  • if (pauseDisplay == true) { // Don’t scroll if we’re at the end of the message*
  • if (thisMs - pauseStart > msgPauseTime) // Has the pause time elapsed?*
  • initialize(); // Yes, so get ready to display the banner message again*
  • else*
  • scrollDisplay(); // We’re not at the end of the message, so scroll away!*
  • // Activate the LED matrix pixels corresponding with matching bits in the respective rows*
  • // and columns of the scroll buffer. Boolean algebra is used to rotate the display 90*
  • // degrees to the right, to match the orientation with the orientation of the breadboard/pcb.*
  • for (int y = 0; y < 8; y++) {*
  • for (int x = 0; x < 8; x++)*
  • if (charBuffer[7 - x] >> (7 - y) & 1)*
  • digitalWrite(colPins, HIGH); // Activate LED momentarily*
  • digitalWrite(colPins, LOW); // Turn off column LEDs before advancing to next row*
  • digitalWrite(clockPin, HIGH); // Instruct the 4017 to advance to the next row*
  • digitalWrite(clockPin, LOW); // on the LED matrix*
  • digitalWrite(resetPin, HIGH); // We’re only using 8 of the 10 outputs, so start over*
  • digitalWrite(resetPin, LOW); // after all rows have been scanned*
    void initialize() {
  • // Prepare to start displaying banner message*
  • for (int i = 0; i < 8; i++)*
    _ charBuffer = 0; // Clear scrolling buffer prior to displaying the message_
    * msgIdx = 0; // Reset pointer to first character in the message*
    * fetchChar(); // Read first character in message and prepare to scroll it*
    * pauseDisplay = false; // No need to pause, since we’re starting over again*
    void fetchChar() {
    * int foundVal = 0;*
    * // Check to see whether we’ve reached the end of the null-terminated message character string*
    * if (charMsg[msgIdx] == 0) {*
    * msgIdx = 0;*
    * pauseDisplay = true;*
    * pauseStart = thisMs;*
    * // For each character in the message, make sure there is a matching character definition*
    * for (int i = 0; i < 89; i++)*
    _ if (charMsg[msgIdx] == charSet*)
    foundVal = i;
    msgIdx++;
    // Load the scroll buffer with the newly-found character (or blank, if none was found)
    for (int i = 0; i < 8; i++) {
    charBuffer[i + 8] = charDef[foundVal * 8 + i];
    void scrollDisplay() {
    // Scroll the current message character one column to the left*
    * for (int x = 0; x < 8; x++) {
    charBuffer = charBuffer << 1;
    if (charBuffer[x + 8] & 128)
    charBuffer = charBuffer | 1;
    charBuffer[x + 8] = charBuffer[x + 8] << 1;
    // After 8 columns have been scrolled, fetch the next character*
    * bufferIdx++;
    if (bufferIdx > 7) {
    bufferIdx = 0;
    fetchChar();
    And picture: http://imageshack.com/a/img855/3978/b1uwd.jpg
    Any help would be much appreciated!_
And we would appreciate if you read the "read this first" post and followed the advice. :roll_eyes:
