Led across two outputs?
The RX pin is connected to the TX of another arduino, and the TX to the RX, so we can comunicate both throught serial comunication. If we can not use the RX pin, we can change the configuration to make the serial comunication with other pins.
But it is possible to make the serial comunication with the 10k resistor and the RX pin conected to the other arduino?
Thanks again!
