I have an Uno which had an LED on pin 2 and audible alarm on pin 9.
I am wanting a sketch to do the following Using multiple timers ;
- blink a Led forever ,
- Sound iitial 1st alrm for 1min after first 6 mins (do this only once) then
- Alarm off off 1 min
- Sound alarm for 1 minute
- Do steps 3 & 4 forever (whilst blinking the LED throughout)
The code below will blink the led & sound the alarm (& turn it off) in a loop , however I'm unable to get the initial first alarm to work. Any help is appreciated, I'm not wanting to use the delay function as it stops the LED.
const int LEDpin = 2;
const int ALMpin = 9;
const long LEDonDuration = 200;// ON time for LED
const long LEDoffDuration = 300;// OFF time for LED
const long ALMonDuration = 60000; // Alm ON duration (milliseconds) 1mins=60000
const long ALMoffDuration = 120000; // Alm OFF duration (milliseconds) 2mins=120000
long rememberTime=0;// this is used by the code for LED
long rememberALMTime=0;// this is used by the code for ALM
int LEDState =LOW;// initial state of LED
int ALMState =LOW;// initial state of ALM
int value = 0;
pinMode(LEDpin,OUTPUT);// define LEDpin as output
digitalWrite(LEDpin,LEDState);// set initial state
digitalWrite(ALMpin,ALMState);// set initial state
// pinMode (9, OUTPUT);
Serial.begin (9600); // initialize serial communications:
Serial.println("Alarm pin Status = LO");
if( LEDState ==HIGH )
if( (millis()- rememberTime) >= LEDonDuration){
LEDState =LOW;// change the state of LED
rememberTime=millis();// remember Current millis() time
if( (millis()- rememberTime) >= LEDoffDuration){
LEDState =HIGH;// change the state of LED
if( ALMState ==HIGH )
if( (millis()- rememberALMTime) >= ALMonDuration){
ALMState =LOW;// change the state of ALM
Serial.println("Pin Status = LO");
rememberALMTime=millis();// remember Current millis() time
if( (millis()- rememberALMTime) >= ALMoffDuration){
ALMState =HIGH;// change the state of ALM
Serial.println("Pin Status = HI");
digitalWrite(LEDpin,LEDState);// turn the LED ON or OFF
digitalWrite(ALMpin,ALMState);// turn the ALM ON or OFF
