Led Analog Clock
Here is my original post: Arduino Forum
well, i've done some reading and think that i found a better way but I would like some people to look at the code before I spend more time finishing it. For the description of the project, refer to the link for the original post.
The leds will be in a 6 by 7 matrix to be controlled but each led will be wired out to a corresponding point around a circle.
here is the code:
int rowPin1 = 13;
int rowPin2 = 12;
int rowPin3 = 11;
int rowPin4 = 10;
int rowPin5 = 9;
int rowPin6 = 8;
int colPin1 = 7;
int colPin2 = 6;
int colPin3 = 5;
int colPin4 = 4;
void setminled(int);
pinMode(rowPin1, OUTPUT);
pinMode(rowPin2, OUTPUT);
pinMode(rowPin3, OUTPUT);
pinMode(rowPin4, OUTPUT);
pinMode(rowPin5, OUTPUT);
pinMode(rowPin6, OUTPUT);
pinMode(colPin1, OUTPUT);
pinMode(colPin2, OUTPUT);
pinMode(colPin3, OUTPUT);
pinMode(colPin4, OUTPUT);
digitalWrite(rowPin1, LOW);
digitalWrite(rowPin2, LOW);
digitalWrite(rowPin3, LOW);
digitalWrite(rowPin4, LOW);
digitalWrite(rowPin5, LOW);
digitalWrite(rowPin6, LOW);
digitalWrite(colPin1, HIGH);
digitalWrite(colPin2, HIGH);
digitalWrite(colPin3, HIGH);
digitalWrite(colPin4, HIGH);
  int timerval;
  int minutes;
  int hours;
  int i;
minutes = 0;
hours = 0;
// set initial time to 6:00
// fully define all the minute pins
digitalWrite(rowPin1, HIGH);
digitalWrite(colPin2, LOW);
digitalWrite(colPin3, LOW);
for(i=0; i>=0; i++)
  delay(120000);
  if(minutes > 29)
    if(hours == 12)
       hours = 1;
      hours++;
  minutes = 0;
 // set led mintues to 0
digitalWrite(colPin5, HIGH);
digitalWrite(colPin6, HIGH);
digitalWrite(colPin7, HIGH);
// clear hour leds
// add function call to set new hour value
    minutes++;
    // clear minutes leds
    setminled(minutes);
    //create function to set minute leds based on last minute
void setminled(minutes)
  if(minutes == 1)
     digitalWrite(rowPin2, HIGH);
   if(mintues == 2)
     {digitalWrite   //continue for minutes and hours
for(i=0; i>=0; i++)
This will always be true. You are saying to continue the loop as long as i >= 0. It starts at 0, and goes up from there.
  delay(120000);
Don't use delay. Look at the Blink Without Delay example.
Also, I'm not sure how you have your LEDs hooked up. If it is a 6x4 matrix that is switched exclusively by the arduino, you need to set the pins you are not using to high-impedance (ie. as INPUT). If one row is HIGH, and all the columns are LOW, one row of LEDs will be on, not just a single one.
How about this? And it is a 6 by 7 matrix. Sorry and thanks.
int rowPin1 = 13;
int rowPin2 = 12;
int rowPin3 = 11;
int rowPin4 = 10;
int rowPin5 = 9;
int rowPin6 = 8;
int colPin1 = 7;
int colPin2 = 6;
int colPin3 = 5;
int colPin4 = 4;
int colPin5 = 3;
int colPin6 = 2;
int colPin7 = 1;
// void setminled(int minutes);
void setminled(int)
  int minutes;
  if(minutes == 1)
   if(minutes == 2)
     //{digitalWrite   //continue for minutes and hours
  int timerval;
  int minutes;
  int hours;
  int i;
  minutes = 0;
  hours = 0;
  for(i=0; i>=0; i++)
    delay(120000);
    if(minutes > 29)
      if(hours == 12)
        hours = 1;
        hours++;
      minutes = 0;
     // clear hour leds
       minutes++;
      setminled(minutes);
delay(120000);
Will not work. Look at the scope of variables, you have to give it a UL type.
how do i use the Unsigned Long exactly? Where do I substitute it in?
6x7 that would be 42 leds, doesn't make sence for a clock... at lease for me. But i'm really intrested in the whole led analog clock thing, i want to have a seriously large 132 led clock (bicolors for minutes and seconds and tricolors for hours. working my way up to that...
delay(120000);
delay(120000) compiles just fine.
This line will make your program stop for 2 minutes. Is this what you want?
That's correct. The delay parameter is unsigned long, so 120000 shouldn't be a problem (other than you're wasting processing power...)
Each led will represent 2 minutes so yes, i want to delay it two minutes. Well if that is not the problem then could someone tell me what is because it is just getting stuck at 6:00 which is just the first command, it won’t change at all. thanks
For testing purposes, replace delay(120000) with delay(500), for example. This way you will see things move a bit faster, if they move at all.
If you need help, you would also need to show a schematic or at least a photo of your setup if it on breadboard.
