LED and Hall Effect Sensor - Inverse Reaction?
I was wondering if it would be possible to write a code that takes the input from a Hall Effect sensor, and as the input increases, a LED dims proportionally. I have this information to work with: -The LED is set to pin 3. -The Hall Effect Sensor is on pin A0. -Standard reading for a HES when no magnet is nearby is ~510. -Maximum reading for a HES, when the magnet is touching it is ~1050.
analogWrite(LEDPIN, map(analogRead(HALLPIN), 510, 1050, 255, 0));
See http://arduino.cc/en/reference/map
I'm not sure I fully understand. This would effectively turn a range of 510-1050 from the HES to a 'backwards range' of 255-0? That part mostly makes sense, but how does the Arduino know that '255' is the maximum for a LED?
elementcollector1: -Maximum reading for a HES, when the magnet is touching it is ~1050.
Where did you get that value from?- Arduino analog inputs are never more than 1023.
elementcollector1: how does the Arduino know that '255' is the maximum for a LED?
It's the maximum for an analogWrite- same as using a digitalWrite to set the pin high.
Yep, it's 1023. Couldn't remember the exact number, so I gave a very rough estimate.
