LED and MOTOR "ON" when A BLE DEVICE APPROACH ESP32 MICROCONTROLLER DFR0575
Hello,
I have this code that is working perfectly but I want my device to start vibrating too (right now only the led is working)
On a Wemos Battery Module I have simply connected the vibration motor on the same PIN of the LED and it works perfectly.
Now I want to do the same on an Beetle ESP32 Microcontroller DFR0575. I used the same code But I can't make the module vibrating (The led is working perfectly)
THE CODE
 #include <BLEAdvertisedDevice.h>
   #include <BLEDevice.h>
   #include <BLEScan.h>
   const int PIN = 2;
   const int CUTOFF = -50;
     pinMode(PIN, OUTPUT);
     BLEDevice::init("tkr");
     BLEScan *scan = BLEDevice::getScan();
     scan->setActiveScan(true);
     BLEScanResults results = scan->start(1);
     int best = CUTOFF;
     for (int i = 0; i < results.getCount(); i++) {
       BLEAdvertisedDevice device = results.getDevice(i);
       int rssi = device.getRSSI();
       if (rssi > best) {
         best = rssi;
     digitalWrite(PIN, best > CUTOFF ? HIGH : LOW);
Please read 'how to use this forum - please read', especially item #7, the go back and edit you post accordingly.
You are more likely to get helpful, friendly advice if you follow the forum rules.
Thank you.
Ok I did it, thanks.
