I'm a beginner with an Arduino Uno and have a question about Led and potentiometer.
I have the really simple following code :
int Pot = A0;
int Led = A1;
int Val;
int Niv;
void setup(){
pinMode(Led,OUTPUT);
digitalWrite(Led,LOW);
void loop(){
Val = analogRead(Pot);
Niv = Val / 4;
Serial.println(Niv);
analogWrite(Led,Niv);
delay(50);
My potentiometer gives information through A0, and my red led is controlled through A1.
When I trace my "Niv" variable, i get a correct value between 0 and 255.
My problem is I don't understand why my red led is only lightening from 128 to 255 with no change in brightness... and stays off from 0 to 128 !
Because the pin you have connected to is not capable of PWM, it is not an analogue output.
On the Arduino PWM enabled pins are marked with a ~ on a UNO these are pins 11, 10, 9, 6, 5 & 3. Use one of those pins.
Hi! Here is a bit harder example, but its working. All u need are 3 LEDs on pins 42, 52 and 30, potentiometer, of course arduino and few wires. Have fun!
pinMode(42, OUTPUT); //defining pins
pinMode(52, OUTPUT); //defining pins
pinMode(30, OUTPUT); //defining pins
int sensorValue = analogRead(A0); //reading from potentiometer
float voltage = sensorValue * (5.0 / 1023.0); //defining sensor value
Serial.println(voltage); //printing voltage in Serial monitor
//now how LEDs are turning on
if (voltage<1) digitalWrite(52, HIGH);
if (voltage>1) digitalWrite(52, LOW);
if (voltage<1) digitalWrite(42, LOW);
if (voltage>1, voltage<4) digitalWrite(42, HIGH);
if (voltage>4) digitalWrite(42, LOW);
if (voltage>4) digitalWrite(30, HIGH);
if (voltage<4) digitalWrite(30, LOW);
